Old 11-21-2016, 09:28 AM   #1
jbgroby
jbgroby's Avatar
Underbed Tire Carrier
I current have and MAY continue to use the in-the-bed tire mount on my fleetside. However, I also have the underbed tire carrier. What I'm unsure of is IF I have all the pieces. The have the frame and the1 long threaded bolt with a nut on it - this I 'think' was the part the bolted to the frame and served as a 'pivot/hinge point' - unsure about that. I'll post a pic this evening.
But I figured that one of you fine folks might already have the knowledge on what and how these mount and work.
Jake
jbgroby is offline   Reply With Quote
Old 11-21-2016, 10:05 AM   #2
PGSigns
PGSigns's Avatar
Re: Underbed Tire Carrier
You should have three pieces. Can see what you are missing once you post pictures.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
