11-21-2016, 01:52 PM | #1 |
shift linkage for 4l60e
ok i have tried the search function and all i seem to get is ads for buying new parts. i have a 66 c10 with factory auto column and a 2007 4.8 and 4l60e i need to connect the column to the trans any post out there that have done this? i refuse to use a floor shift so no need to even mention them.i was thining a cable like factory 07 used and a couple brackets. but i have seen linkage rod kits. i know someone has done this at some point. help please
11-21-2016, 02:31 PM | #2 |
Re: shift linkage for 4l60e
Lokar
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-21-2016, 06:39 PM | #3 |
i used the stock rod down to the side of the frame and then from there i went to the salvage yard and grabbed a few bell cranks as fab stock to make what i want. Purchased from gm a new white plastic cup for the frame mount pocket and then worked with factory manual lever that attaches on the trans. I would tack weld up various layouts untill i had full travel into manual low and all detents work. Took some time but works nice.
A shift cable will probably be easier. If gm used it on a truck with a od trans i would try that. Good luck. |
11-21-2016, 10:09 PM | #4 |
12-05-2016, 03:09 PM | #5 |
just an update.... snagged an OE cable from a 2004 tahoe attached on trans side with factory bracket. turned the pivot point on column around facing firewall attached cable built a bracket for the cable mount bolted to inner fender. works well so far and i have about 4 dollars in the project
12-12-2016, 08:29 AM | #6 |
Ditto on Hart Rods recommendation (Lokar). Just make sure to be patient with the install. I jacked up my first install by cutting the rod to short-couldn't get the shifter to 1st gear. Measure 4 times cut once.
12-12-2016, 01:02 PM | #7 |
lokar user here too
12-12-2016, 02:08 PM | #8 |
FYI, You can buy the rod by itself if you need a new one.
12-12-2016, 10:08 PM | #9 |
That's exactly what I did Hart Rod. Install pending warmer weather.
12-13-2016, 02:09 PM | #10 |
lokar universal shift linkage here as well
