11-21-2016, 04:55 PM | #1 |
Dash Bezel HELP!
So I screwed up and ordered a 78/80 dash bezel from lmc some time ago now that mu truck is going back together I found out cab was changed to an 82 grrrr. Is there any way to make it fit the newer cab. Shipping back not an option had the money 2 years ago to but the dash and I'm in Canada I would lose have its value.
11-21-2016, 07:37 PM | #2 |
Re: Dash Bezel HELP!
As long as you use a 73-80 dash pad the bezel will work fine a direct fit
11-22-2016, 01:41 PM | #3 |
11-22-2016, 04:37 PM | #4 |
That is the dash pad it will fit in your cab the only thing is you may have to alter the area where the vin plate is mounted in the cab to fit the opening in your dash pad if it's a 78 the vin should be in the door jamb
