Old 11-21-2016, 10:05 PM   #1
karlbenz
heater control knob
64 gmc. has the single cable pull twist control. I have a cable. Any idea where to find the knob? can't seem to find one
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 11-22-2016, 08:28 PM   #2
karlbenz
Re: heater control knob
anyone know of something that could be modified to work?
1965 Chevy C60
Old 11-23-2016, 12:12 AM   #3
forestb
forestb's Avatar
My chevy has one plastic knob in the dash that lights up where the controls usually go. That you turn to make the heat come on and then a different pull nob near the steering column that when you pull it, it turns on the defrosters. Is one of those what you are talking about?
forestb is offline   Reply With Quote
Old 11-23-2016, 01:39 AM   #4
Kenfuzed
Kenfuzed's Avatar
Not sure about GMC but on my C10 I have the single cable/knob heater (Thrift Air) and also could not locate a knob. I finally bought a wiper knob that didn't have the hole meant for the washer button and it had a set screw to grip the shaft of the heater cable. Some headlight knobs also have a set screw that will work.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 11-23-2016, 08:13 AM   #5
karlbenz
Mines the thrift air heater. one cable. pull the cable for heat and turn for fan speed. there is a lever under dash for defroster
1965 Chevy C60
Old 11-23-2016, 08:15 AM   #6
karlbenz
yep, same heater. guess I'm gonna have to look at doin something like that too. can't believe someone doesn't make one
1965 Chevy C60
Old 11-25-2016, 04:20 AM   #7
Kenfuzed
Kenfuzed's Avatar
Just looked at a repop headlight knob from The Truck Shop I have and it has a allen key set screw so it may work.
Enjoying the ride!
