Need Help with VIN Number 1960 Chevy Pick up
Hello
I Need your Help about a Vin Nr... A Friend of mine here in Germany has bought a 1960 Chevy 1/2 ton Chevy Pick up Long bed.. He have some Problems with the Vin Nr Number is 0C1540118970 with this Number we couldn find where it was build so we Change the Number after 4 into a O Letter... so it tell us 1960 1/2 ton Pick up build in Oakland But now they told us here in Germany O wasn t in 1960 Would be realy great if someone can help us further !!!!!! Thanks a lot Greetings Mike |
Re: Need Help with VIN Number 1960 Chevy Pick up
So what do you need? You have it correct. The tk was built in Oakland California. weather is a o or a zero in the vin it was still built in Oakland. The Oakland plant was in Oakland from 1916 to 1963 which in late 63 moved to Fremont California. goggle Oakland assembly plant in Oakland Ca for all the info you need. good luck
1961 chevy K10 my build is------------61K10 build |
Moderator
![]() ![]() Join Date: Aug 2011
VIN Info: http://67-72chevytrucks.com/vboard/s...d.php?t=463671
http://67-72chevytrucks.com/vboard/s...d.php?t=316902 http://www.oeltd.net/doc/6066gmc/VINs/gmc-canada.htm Ihr willkommen. ![]()
#4 | |
#5 | |
