Bed to Cab Gap
I want to close up the gap between bed and cab, anyone done this? I think it would improve the looks if I could move the bed forward 7/8", sounds simple, but seldom is. Your thoughts?
Diggin The SquareLife
Re: Bed to Cab Gap
I wouldnt bother doing it
Re: Bed to Cab Gap
If you close the gap too much you run the risk of hitting the cab with the bed when it flexed.
If you do it you need to consider the centering of the wheels in the wheel well, the rear bumper sticking out, and your fuel fill hoses night lining up as well.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Re: Bed to Cab Gap
The gap is very close to 1", so maybe moving 3/4" is more prudent and this will move the wheels more to the center of the wheel well than it is now. Moving he bumper forward is easy. Been looking at aftermarket gas doors that would need doing at the same time. I'm guessing the biggest thing is welding mounting holes closed and redrilling them forward. I suppose I could make a unibody out of it.
Re: Bed to Cab Gap
Maybe you could get a couple old bedsides and cut off the front edges and weld them to the existing to close the gap. this would mean not having to move axles, bumpers, filler necks, etc.
Re: Bed to Cab Gap
Before doing anything, I suggest you ride in the bed while someone else drives your truck over some rough bumpy terrain. I think you will be surprised at how much flex there is between the bed and cab. Observed this first hand as a kid riding in PU beds.
