Old 11-22-2016, 09:37 PM   #1
custom10nut
custom10nut's Avatar
Half dash lights not working
Yesterday when I checked, it looked like I had one bulb, on the right side of the speedo, not on. But tonight when I went to troubleshoot it, the only lights on are the gas gauge.
I put new bulbs in last week, and it didn't blow a fuse.
All the other lights that work off the headlight switch (new) work fine, and this has not been an issue before.
Any ideas?
custom10nut is offline   Reply With Quote
Old 11-22-2016, 10:26 PM   #2
rustytruck50
rustytruck50's Avatar
Re: Half dash lights not working
Printed circuit?
I have the same issue, but haven't had the chance to get into it....
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 11-22-2016, 10:44 PM   #3
custom10nut
I thought about that too. What confuses me is that it was working fine yesterday. I think I'm going to unhook it in the morning and clean the contact, like I should have done while I had it out last week.
Old 11-22-2016, 11:06 PM   #4
rustytruck50
Strange as it sounds, if you've had any humidity or damp issues, it could have that quick of an issue...
-Doug
'05 RCSB Sierra 2WD
Old 11-22-2016, 11:25 PM   #5
dmjlambert
dmjlambert's Avatar
When I took out my instrument cluster, I polished the printed circuit contacts and the contacts on the bulb holders gently with Brasso and a Q-tip. It cleaned them up and made them shiny.
dmjlambert is offline   Reply With Quote
Old 11-22-2016, 11:31 PM   #6
rustytruck50
Sounds good...you might even want to put a small dab of dielectric grease on the tabs to help future tarnishing.
-Doug
'05 RCSB Sierra 2WD
Old 11-22-2016, 11:32 PM   #7
custom10nut
It looks like I'm going to take the dash back out and do a little cleaning.
Thanks for all the responses.
I'll update tomorrow
Old 11-23-2016, 10:17 AM   #8
custom10nut
The electric grease is a great idea.
Is the circuit for the lights a series, because that would explain why they all stopped working at once.
Old 11-23-2016, 11:00 AM   #9
LongBox
The lights are wired in parallel, not series.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 11-24-2016, 10:38 AM   #10
custom10nut
I toyed with it last night, and still no lights. The gauges all work so, it's got to be a connection issue. Now to find it.
Old 11-24-2016, 11:00 AM   #11
dmjlambert
dmjlambert's Avatar
Check for broken brass tabs on your bulb holders, I had one or two of those bulb holders that were bad. New ones at Advance Auto Parts are fairly expensive at about $8 so that was annoying. But I bought it anyway because I was feeling like just getting it done that day.
I tested my instrument cluster while on the workbench, by attaching a ground strap between the negative of a battery and the metal of the cluster, then touching positive to pin 8 of the place on the printed circuit where the connector plugs in. You can't really use an alligator clip because the metal of the case is what the bottom jaw of the clip would grip, so it is easy to short out your 12V.
http://67-72chevytrucks.com/vboard/s...d.php?t=709847
If you need a printed circuit, I see new are available for online at various stores. Manes Truck Parts has used ones for $25.
Old 11-24-2016, 02:57 PM   #12
custom10nut
All my tabs ar good, I just took them all out yesterday, and cleaned them. What I didn't do was clean the contact points on the printed circuit. I'm gonna take it out and most likely get a new printed circuit
