11-22-2016, 11:08 PM | #1 |
is it just me or is this not right?
Anyone else think it's weird that instead of a wheel base length this SPID is showing the paint code is this fishy or something I am not use to? |
11-22-2016, 11:28 PM | #2 |
Re: is it just me or is this not right?
Nope looks right. Depends on manufacturing plant.
11-22-2016, 11:29 PM | #3 |
11-23-2016, 12:13 AM | #4 |
So what do you guys think of this find and what do you think of the frame patch job? I'll have to fix it I think |
11-23-2016, 12:15 AM | #5 |
Has no motor but they guy only wants 2k for it
11-23-2016, 12:59 AM | #6 |
11-23-2016, 11:50 AM | #7 | ||
"I ain't nobody, dork."
That much rust it's pretty much a goner. Too many people think they still have a gold mine because of the year of the rig.
I wouldn't give more than $500 bucks. And use it for parts. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
11-23-2016, 12:13 PM | #8 |
Moderator
I'd have a hard time giving $200 for that, let alone 2K
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-23-2016, 12:28 PM | #9 |
I grew up in Northern Minnesota, where we would consider that amount of rust "not bad." The frame repair is scary, though.
11-23-2016, 12:55 PM | #10 |
three words you don't want associated with a truck you are buying:
frame patch job
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
11-23-2016, 02:16 PM | #11 |
Looks like that frame patch is After the Rear Axle? Is that the only patch? Most of the stress on the frame is right after the cab. My '67 has a lot of cab rust, much worse than these pics. The rear spring perch is failing on mine, but I am going to rebuild and re-strengthen the chassis, possible short bed conversion. Doing it right w a Z cut and plate reinforcement or boxing.
That rear patch is done with a straight cut and that is not the best way, but it is in the rear. That cab looks a lot less rust than what I have, but do you have more pics that show better angles of the damage? How much work do you want to do? I paid about $1800 for mine, had more rust than what you're posting but it came w original 283 w 9k miles. |
11-23-2016, 11:55 PM | #12 |
Hey I'm no expert, and I'm in southeastern Kentucky, but I gave $50 for my truck and other than some rusted out rockers/floor pans, minor other rust, everything else was numbers matching, all original, and the frame was perfect! You can check my thread if you want to check it out. My truck was a LWB and I've shortened the frame already on it. If you or your friends are competent welders, it's an easy job. Just another option to think about! Good luck, but I for SURE would pass on that truck.
11-24-2016, 12:10 AM | #13 |
I am surprised at how many people are scared of frame repairs given how many people are willing to butcher the frame to turn a truck into a SWB.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
11-24-2016, 12:14 AM | #14 |
I definitely ain't afraid of any frame repairs but I don't think I butchered mine either haha if you're a qualified welder, frame work is no big deal as far as I'm concerned!
11-24-2016, 01:20 AM | #15 |
Nicely put.
1982 K10 SWB 1987 V20 - Sold - Doh! |
11-24-2016, 06:40 AM | #16 |
Frame repair , Cab repair , Engine repair ................ if it all done correctly the doors will shut ,the engine will start and the truck will drive down the road just fine for many miles and many years
