Old 10-11-2003, 03:05 AM   #1
1FaastC10
1FaastC10's Avatar
dual capacity accelerator pump?
i've got a Quadrajet with the electronic dual capacity accelerator pump. what would happen if i ran it without being plugged in? woudlnt it jsut run like a regular QJet?
1FaastC10 is offline   Reply With Quote
Old 10-11-2003, 09:40 AM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
No, it would work just the opposite. The way it works is it is in dual capacity operation when cold. When the engine reaches around 160, the solenoid opens and functions as single capacity. So in other words, it would always be squirting extra gas in.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-11-2003, 11:48 AM   #3
1FaastC10
1FaastC10's Avatar
well, extra gas means extra power, right? i think the ol 305 needs all she can get!
looks like i'm EBaying for a QJet then. unless someone has one?
Old 10-11-2003, 12:51 PM   #4
mhorning
mhorning's Avatar
Jeremy
is that the m4med?
63 Chevy C10
86 Chevy K10
mhorning is offline   Reply With Quote
Old 10-11-2003, 07:43 PM   #5
1FaastC10
1FaastC10's Avatar
uhm, i dunno, is it? its a Quadrajet with that stupid little electrical plug on the top.
Old 10-11-2003, 08:56 PM   #6
swervin ervin
Yes, it's a M4MED q-jet.
Old 10-11-2003, 09:22 PM   #7
mhorning
mhorning's Avatar
I have an extra that I bought from one of the guys on here a few months ago. I thought my truck was going to need one, but it turns out that the carb wasn't the problem. I paid 75 for it. I was told that it worked fine when it was removed, but I haven't actually tried it out. If you're interested, I can send it to you. If it turns out the carb doesn't work, I'll send you the money back. Of course, if it were me, I'd use it as an excuse to get the edelbrock 1904.
63 Chevy C10
86 Chevy K10
Old 10-11-2003, 09:52 PM   #8
1FaastC10
1FaastC10's Avatar
i appreciate the offer, but what i've done is eliminate the system altogether. it was tied in with the ESC, the only thing remaining from the ESC is the hole in the firewall and the control module under the dash, because i havent got around to pulling it out yet.
Old 10-11-2003, 11:52 PM   #9
crackajacka
Stylin
crackajacka's Avatar
ive got my old 305 if anyone wants it come and get it and it shall be yours.
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 10-12-2003, 12:06 AM   #10
mhorning
mhorning's Avatar
so what else did you have to remove? Can you use your old distributor? I only ask, because, I think I will wind up doing the same thing eventually.
63 Chevy C10
86 Chevy K10
Old 10-12-2003, 12:17 AM   #11
crackajacka
Stylin
ask swervin ervin about that i think hes got instructions on how to do that
Old 10-12-2003, 03:21 PM   #12
1FaastC10
1FaastC10's Avatar
i could've used the old distrubutor, but since i thought i had a bad one i put a standard vac advance HEI in it. if you remove it, you'll also have to rewire the TCC lockup as its part of that harness if i remember correctly.
