Starter Problem
Have anyone had a problem with there starter when attempting to start it makes a really awful noise. I have a 1969 step side C-10 with a SBC 400 and I have replaced the flex plate using the old starter the problem got a little better but still can here the that noise. I have replaced the starter with a new one and it worked great for a few days and then that awful noise can back at this point I am lot and need help.
Re: Starter Problem
Check the engagement between the starter drive and the flexplate. There are usually some shims in there that determine the depth of engagement, and you may not have it shimmed right.
Re: Starter Problem
thanks for the reply what would make it work well for a short time and then start back to making that noise?
Re: Starter Problem
That's what made me think of the shims. It might sound fine until the teeth start to eat each other.
Re: Starter Problem
Any chance you put the flex plate on backwards? That'd do it... and it's an easy mistake to make.
Re: Starter Problem
I'm pretty sure I have it on wright it was making this noise when I purchased the truck a little while ago I have the starter out and I will install a shim and check it with a paper clip to see how much clearance it has. I will send the new starter back and use the original one that was on the truck when I purchased it. thanks everyone for there support I will keep you posted on the out come I hope this dose it this has been a nightmare
when trying to start the truck it sound like the starter is kicking out from the fly wheel or flex plate |
Re: Starter Problem
Too much timing will make it kick like that.
Do you have the correct knurled shoulder bolts and a starter brace? |
Re: Starter Problem
I purchased a set of knurled bolts from Jegs however they don't fit my starter they are to big the starter dose have knurled bolts currently on it I also believe it it is not correctly timed I have been playing with the timing and I'm sure it out of timing I don't have a timing light so I put it as could. I have a friend with a timing light I will try to time it correctly and go from there thanks I will keep everyone posted on the out come.
Re: Starter Problem
Also make sure the knurled shoulder bolt heads are tightened against the starter case tight.. I purchased a rebuilt starter with bolts onceand they were slightly too long...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Re: Starter Problem
Re: Starter Problem
Another idea is if it starts right 1 or 2 times then grinds you may need the front brace to keep the starter from flexing flexing.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: Starter Problem
#13 | |
Re: Starter Problem
http://67-72chevytrucks.com/vboard/s...d.php?t=492532 |
#14 |
Re: Starter Problem
Pic here.
http://67-72chevytrucks.com/vboard/s...d.php?t=537319 Summit has them. Your local parts place might. https://www.summitracing.com/int/par...4353/overview/ |
#15 |
Re: Starter Problem
I have no problem buying a brace for the starter however will the brace work on a mini starter. I see the brace mostly on factory starter.
yesterday I had a few tip about shimming the starter so I remove the starter from the block and added 2 shim across both holes on the starter it appears to have made a bit of a different but still grinding notice that when trying to start the engine when it has compression up it kick the starter back should I put another shim on one side? what I was going to try next is measuring the clearance which I have not done yet never did starter clearance check before any thoughts |
#16 | |
Re: Starter Problem
http://www.remyautoparts.com/The-Lat...PG-%28PG260%29 As for a brace for these new starters, I've never seen one anywhere except on industrial 4 cylinders. You'd have to make one... |
#17 |
Re: Starter Problem
one thing that stays on my mind is I purchased a new starter and it worked fine for a few days and after that it starter back to making that grinding noise again so I put the old starter back on and return the new one this is driving me crazy so you don't think it is a shim problem with the starter? going to start back on it tomrrow
#18 |
Re: Starter Problem
If it worked for a few days and then started grinding, my money's on the starter loosened up. Wrong bolts or holes wallowed out ( from wrong bolts ). Is it a brand new starter or reman? I've seen remans with the holes already wallowed out.
#19 |
Re: Starter Problem
I will change the bolts but yes the new starter was fine for a few days of cranking this is when I thought I had fix the problem but as I mention the noise came back I need to fine out what is the correct size for the Jeg starter that is mounted
#20 |
Re: Starter Problem
Also, when you have the starter off, have a very close look at the bolt holes in the block and surrounding metal. Sometimes it cracks from too much starter movement over time and then no starter will stay tight.
#21 |
Re: Starter Problem
wow do that mean new block needed
#22 |
Re: Starter Problem
I have same problem with 383 in my 68, flywheel is on correctly and starter is shimmed. If you come up with anything please share as it is completely aggravating
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#23 | |
Re: Starter Problem
I left mind along for a few days but I will go back to it and I will post if anything change this is out of control I have a place near me that they work on starter only he ask me to bring him my starter and the old flex plate that I replaced and he will look it over and and tell me what he see wrong by looking at the flex plate and the starter going to go there tomorrow just need to take the starter off again for 100 time if you come up with something post it also |
#24 |
![]() Join Date: Feb 2009
Re: Starter Problem
I had this problem with a new starter. It may not have been the starter after all, but I replaced it with another. Yes I used shims on both, but I didn't work out the problem until after I installed a new battery. That was my experience anyway.
Just remembered, that first starter was "special" I returned it to Napa and they said it wasn't there's. I may have gone off some, wasn't happy. So yeah, it was probably bad.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#25 |
Re: Starter Problem
i have fought starter issues on my last 2 big blocks, but never with a small block. On my 11.5 to 1 396 the only thing I found that fixed the issue was a high torque mini starter. On my current 454, I had a combo of a bad flex plate and no brace causing the issue. I ended up just putting a mini starter on it as well. I would bet there is just enough wear in the flex plate to cause the grinding, it may only be in one spot which is the reason it works fine for a while and then grinds depending on where the engine stops when you turn it off.
