Truck stalls when I select left tank
Last week I replaced the three (3) short rubber fuel lines that go between the sending unit and the hard lines for the left tank of my truck.
Now once my truck is running, if I select the left tank, after about ~1 minute at idle, the truck dies. With the right tank, no issues at all. I'm thinking I must have done something when replacing the lines from the sending unit to the hard lines. From what I remember, I reconnected them in the same order from the sending unit to the hard lines. The sending unit line near the front of the truck went to the first hard line near the front of the truck. Middle to middle, and rear on sending unit to rear hard line. I'm thinking maybe that wasn't the correct order? Any suggestions? |
Re: Truck stalls when I select left tank
Also, the left tank has some pressure to it when I remove the gas cap after I try to run the truck (until it dies). I tried running it with the gas cap off, it still dies after about 1-2 minutes after switching from the right tank at idle. The gas gauge also displays the correct level for both tanks.
Had the same issue ended up putting new hard line under the cab and it fixed it
The sending units go bad over time-the screen literally deteriorates and it lets crap get into the crossover line. I priced a set of lines from Inline Tube because I didn't want to mess with any old fuel lines. $232 total for pump supply/return to selector valve and the crossover lines with all the correct frame clamps. My lines had crud and rust inside of them.
I can see a sending unit going bad, but I feel it's a coincidence it went bad the day after I dropped my tank. I'm starting to think I possibly clamped the rubber hoses too tight???
I had the same problem on my '84 dually recently, but with both tanks. I ended up pulling the sending units and cleaning them. They really weren't too rusty and both were showing correct readings on the gauge, but the pickup screens deteriorated and pieces of them clogged the lines up. Once I got everything loose I blew all the lines out with air, haven't had a problem since. The steel lines were surprisingly clean as well. I bought new pickup screens to put on the sending units as well, the part number is 5651711.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Moderator
![]() Join Date: Oct 2008
Assuming this is a 1981-1986 CK or 1987-1991 RV pickup truck...
The 3/8" ports are supply and the 5/16" ports are returns. The engine side of the valve only has one of each. To and from the engine. The tank side of the valve has a pair for each side. To and from a tank. The motorized valve shuttle only opens one set of these.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Just here to tinker
![]() Join Date: Jun 2008
When the switching valve fails, it defaults to the passenger tank. Perhaps the valve died.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#10 | |
Moderator
You are correct for 1980 and prior GM pickups with solenoid tank valves. 1981 and later motorized tank valves retain the last selected position. If they fail in that position that's where they stay.
#11 | |
![]() Hatzie you're my square body guardian angel mechanic. I owe you a lot of beer. |
Moderator
You can't tighten hose clamps enough to collapse the steel sender nipples or the steel fuel lines.
I'd disconnect the supply line crossover tube from the valve and the tank and blow shop air through it from the valve end. Check that you didn't kink a hose when you put the tank in place. I usually try to put a loop in each of the three hoses rather than straight onto the lines. For the SAE J30R9 "rubber" tank lines I'm a big fan of the constant tension band clamps for ease of installation on small lines and in tight places. No worries about not getting them tight enough or too tight either.
#13 |
I'm in the middle of working on this. I dropped the tank, short rubber lines looked okay. I removed them and noticed they each had a crease, so I'm thinking I must have kinked them when i reinstalled the tank. I ran a hose from the supply line to a 5 gallon tank to see if it's pulling fuel, and it is. Reinstalled the 3 lines with the tank semi-dropped and it's running with no issues. I'm thinking I must have kinked the lines during the reinstall. I'm an idiot.
#14 |
Reinstalled with shorter lines, all is well. Thanks for everyone's input!
