Old 11-25-2016, 08:46 PM   #1
dave666693
dave666693's Avatar
Heavy loads help
I have a 1971 GMC 4x4 3/4 ton on leaf springs. This is mainly a farm truck. I haul 2 yards of gravel at a time and need options on beefing up the rear suspension. In the old days you could take your leaf springs to a shop and have leafs added. Is that still the case?
Should I get a modern overload spring kit, air bags or just look for some 1 ton springs and swap them out?
Thanks in advance for any help!
Also considering a narrow dually rear end. Is that an easy swap?
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 11-26-2016, 05:56 AM   #2
andrewmp6
Re: Heavy loads help
Do you have a spring shop locally to you ?If not talk to http://www.denverspringandsuspension.com/ they have custom made me springs in the past.If they can't do it http://offroaddesign.com/ can do it also.I would have custom springs made or grab 1 ton springs.As far as the rear end if it came out your trucks body style it might just bolt in.If you want a later rear end moving the spring perches and shock mounts are in order.Its just cutting and welding tho.
andrewmp6 is offline   Reply With Quote
Old 11-26-2016, 12:11 PM   #3
ranger danger
ranger danger's Avatar
The simple answer is Yes, you can find a local spring shop and just add leafs. You would be better off with a new spring pack. 2 tons is a lot of weight on a 3/4 ton diff. Something like a Dana 80 would be better. I know they were stock in the 1995 through 2001 dodge ram's with the diesel in single tire (not duel).
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
