Old 11-26-2016, 10:47 AM   #1
bluex
bluex's Avatar
Aluminum Diff cover - panhard clearance
Looking at the aluminum diff covers with the bolts to brace the main caps. Anyone used one of these on a trailing arm setup with a longer/not stock panhard bar?
I have a porterbuilt setup I'm installing an the bar runs from the dr side to the pass side at the trailing arm. I'm looking specifically at the LPW low profile cover #201-12T, It says on Jegs that it wont interfere with the bar on a lowered truck but I'm wondering if thats more for a stock bar that isn't as long?
http://www.jegs.com/i/L.P.W./619/201...FRc8gQodLDEC6g
bluex is offline   Reply With Quote
Old 11-26-2016, 11:19 PM   #2
racecougar
racecougar's Avatar
Re: Aluminum Diff cover - panhard clearance
While these photos are of a stock location panhard on a '65, it may give some idea of how far the cover sticks out.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 11-27-2016, 07:05 AM   #3
bluex
bluex's Avatar
Thanks! I would assume that the ultimate cover is thicker than the low profile one to so it should have a little more clearance on top of that....
Old 11-27-2016, 11:41 AM   #4
racecougar
racecougar's Avatar
Right. You should have a little more clearance with that cover.
