Old 11-26-2016, 12:01 PM   #1
Toms67
Toms67's Avatar
What crossmember to use. Muncie M 21.
What crossmember to use. Muncie M 21. I don't have the bell housing that came with the truck. It had a three on the tree. The op put a GH 400 in it. I would like a crossmember that would allow me to run my exhaust up in the frame. Thanks for looking.
Toms67 is offline   Reply With Quote
Old 11-26-2016, 05:49 PM   #2
firedemon
Re: What crossmember to use. Muncie M 21.
should be able to use the automatic crossmember with that trans
firedemon is offline   Reply With Quote
Old 11-26-2016, 06:48 PM   #3
ryanv70c10
I know that the TH350 and PG cross members work on a Muncie in a Nova with out any modification at all. So if you have a TH350 unit you should be good to go.
ryanv70c10 is offline   Reply With Quote
Old 11-26-2016, 06:55 PM   #4
Toms67
Toms67's Avatar
Thank you for the replies. I will check into that.
Old 11-26-2016, 08:33 PM   #5
coreyjhen
I'm confused. How many different crossmembers were available stock?
coreyjhen is offline   Reply With Quote
Old 11-26-2016, 09:14 PM   #6
Toms67
Toms67's Avatar
The Muncie M 21. That I am using Was not available on these trucks. So I have to use one that will work with this transmission.
Old 11-26-2016, 09:19 PM   #7
firedemon
one for the manual that mounts to the bell housing and closer to the motor and one for the automatics that mount to the tailshaft obviously further away from motor
