Old 11-26-2016, 03:56 PM   #1
ACII
drag race transmission ? for LS1
Hy all
after using the ls1 in my chevy pickup for the first season , i am totally happy and impressed by the 4gen engines :-)
therefore i am looking for another Project with an LS1 engine ... i am planning to setup a car for the 1/4mile .....
the ls1 will be swapped into the middle of the car.. according to the short wheelbase i dont have that much space to the rear axle.
So do u know which Transmissions are the shortes on the market ? and can handle around 1000 hp
Is there also possibilty to bolt a axle housing directly to the Transmission without a driveshaft ???
I know some weird questions but i hope u can give some informations :-)
Thanks a lot
Achim
ACII is offline   Reply With Quote
Old 11-26-2016, 05:34 PM   #2
solidaxel
solidaxel's Avatar
Re: drag race transmission ? for LS1
Mid engine ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-27-2016, 08:43 AM   #3
ACII
yeap the car has a mid engine.... it is a VX220 ..does have the same Frame / wheelbase than the Lotus elise...
The car respectively the frame will be lengthen to get the LS1 swap done.
At the end something like Hennessey did with the venom gt.
CU
Achim
Old 11-27-2016, 11:10 AM   #4
e015475
e015475's Avatar
Google "shorty powerglide" and see if that might work for your project. Its a very common drag race transmission in the states.
e015475 is offline   Reply With Quote
Old 11-27-2016, 11:55 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There is a Toyota-built trans thats basically a 2/3 scale copy of the powerglide, often called the ToyoGlide. It can't hold nearly that power in factory form, but there are builders that have made custom versions of it for specialty builds.
Otherwise I 'd suggest looking at a LencoDrive. Its a drag built trans for promods and fuelie cars.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
