![]() Join Date: May 2006
Need Help
Advice on an adjustable proportioning valve, which one, manufacturer, ideas. Just blew my hydroboost system apart, and thought it would be a good idea to install it now
Also, need to see pics of the clamps that hold the rear wiring harness to the frame Any input would be helpful...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: Mar 2004
Re: Need Help
I got my prop valve from Hydratech. It was like $50 bucks. Works great.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: Need Help
I built my own, used the wilwood prop. valve. As for the wiring clips, Ive probably got pics in my files, however mine is a 2wd.
#4 | |
Re: Need Help
thanks Tom, what about the brake light, do you still use it
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-27-2016 at 11:09 AM. |
