Old 11-26-2016, 07:27 PM   #1
roushinator
roushinator's Avatar
Left over Parts...
For sale is some parts i have left over and just sitting here. PM me if you're interested and we can figure out shipping to your location.
Weiand SBC 7546 Intake - Used $50
CVR Fuel Pump Block Off Plate. New. $20
ECE Crossmember New - Mounted but never driven with... $175 SOLD
72 C10 Gauge Cluster - $50
SBC Dress Up Kit. It is Crinkle Black with Red accents.
It comes with the following:
Valve Cover Wing Nuts (2) - 141-756
Valve Cover Hold Down Clamps (2) - 141-757
Timing Cover - 141-753
Valve Cover Air Breather (2) - 141-754
14" Air Cleaner - 141-752
Valve Covers - 141-928
POR15 Engine Painting Kit - Chevy Red
I paid over $500 for all of this. Looking to get $350. Everything is new and never installed.
72 C10 6 cyl motor mounts $20
72 C10 Body and Radiator Core mounting brackets - $20 SOLD
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 11-26-2016, 10:12 PM   #2
zicc1835
zicc1835's Avatar
Re: Left over Parts...
ill take the SBC motor mounts and cores support brackets to 07981
zicc1835 is offline   Reply With Quote
Old 11-26-2016, 10:33 PM   #3
randy500
Those are 6 cylinder engine frame mounts.
randy500 is offline   Reply With Quote
Old 11-26-2016, 11:12 PM   #4
roushinator
Well my truck was a factory 350 and those came out when I removed the worn out 350 engine. But you might be right I don't know.
See post above and see if you still want the motor mounts.
Ryan...
Old 11-26-2016, 11:31 PM   #5
zicc1835
zicc1835's Avatar
ill pass on the MM mounts but will take the core and body mounts
Old 11-26-2016, 11:35 PM   #6
zicc1835
zicc1835's Avatar
thanks Randy !!
Old 11-27-2016, 10:34 AM   #7
randy500
I'm not trying to interfere with your thread, just trying to help the buyer and seller...
A V8 will mount up to those but it will be mounted back close to the firewall and is not the stock V8 location. Those mount to the rear set of frame rails and V8 mounts locate to the front set of holes and are shaped different. You can tell the 6cyl mounts by the way they flare out at the top where the 2 mounting holes are located. V8 mounts also sweep back on the lower bolt in reference to the top bolts.
Old 11-27-2016, 12:55 PM   #8
Dustmaker65
Dustmaker65's Avatar
Probably not the best place to discuss this, but we can move if needed...
Randy do you have both sets of mounts(6 & 8 cylinders)?
I do not have any 6 cylinder. but several sets of V8, and all look like the ones the seller has listed.
Thanks!
Jimmy
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 11-28-2016, 03:52 PM   #9
roushinator
Updated original post with sold items... More to be added soon.
Ryan...
Old 11-28-2016, 10:44 PM   #10
70c10resto
70c10resto's Avatar
If the sale doesn't work out on the trailing arm crossmember I will take it. Thanks
70c10resto is offline   Reply With Quote
Old 12-03-2016, 08:29 PM   #11
zicc1835
zicc1835's Avatar
ECE Crossmember New - Mounted but never driven with... $175 sale pending
mounts showed up a few days ago thank u
Old 12-04-2016, 09:29 PM   #12
roushinator
Removed the sold items from the original post.....
Ryan...
Old 05-16-2017, 11:26 PM   #13
60n60Apache
Do you still have the SBC engine mounts?
60n60Apache is offline   Reply With Quote
