72 GMC C2500 Stock suspension Tires rubbing
Front passenger tires rubbing on front fender where fender and wheel well come to a point. Running 285/75/16's on 16 x 8 Ion's with 4" backspace. Is there a suspension mod or slight lift that's inexpensive. Possible smaller tires say 265's or minor cut some metal away but not too excited about cutting my truck. Smaller tires perhaps? Thoughts?
#2 | ||
"I ain't nobody, dork."
Re: 72 GMC C2500 Stock suspension Tires rubbing
Those are big tires... I'd say go smaller.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Biiiig tires up front of that old girl
1967 Chevy CST 10 1969 Chevy C/20 Longhorn 1969 K10 Suburban 1972 Chevy Cheyenne Super 10 turned K30 (sold) ![]() |
I went with slightly larger springs on the front of my C20 and it gave me an inch or so of clearance. Here is the link that I used... http://67-72chevytrucks.com/vboard/s...+self+leveling
Whatever you do, do not go with anything over 10" of spring load height as it will NOT work for your truck. Last edited by Aruba1; 11-28-2016 at 09:57 PM. |
Too big a tire and too little backspacing. One or both of these needs to change if you don't want to trim the "fang" off the front fender cup.
Thanks for the input.....I think I'll go with something like 265/75/16 all around. I believe that should fix the problem.
Posted via Mobile Device |
