Old 11-29-2016, 04:11 AM   #1
j.rigby15r
j.rigby15r's Avatar
Airbags/airlines in subzero temperatures questions
So I live in the interior of Alaska. It is currently in the negatives and this weekend it's supposed to be -32f. I am finally finishing the Air suspension on my 64. I am worried about having issues in my air system due to the cold, for example air in the lines freezing, airlines cracking due to being cold or compressors acting up because they are to cold. Has anybody experienced this or have any advice? Thanks as always.
j.rigby15r is offline   Reply With Quote
Old 11-29-2016, 06:19 AM   #2
andrewmp6
Re: Airbags/airlines in subzero temperatures questions
Go to any parts store and ask for airline antifreeze,They use it in the air system on semis.You will have to drain the system of air to add it and you only need about half a cup of it depending your tank size.
andrewmp6 is offline   Reply With Quote
Old 11-29-2016, 05:46 PM   #3
j.rigby15r
j.rigby15r's Avatar
That's what I was thinking about. Didn't know if I needed to do anything with the compressors.
Old 11-29-2016, 11:53 PM   #4
andrewmp6
The compressors i have no idea on,I never seen one freeze here but your way north of me and see a lot colder temps them i do.Do you have a heated garage to keep it in ?Or is it outside all winter.
Old 11-29-2016, 11:56 PM   #5
j.rigby15r
j.rigby15r's Avatar
She sleeps in the garage. But she will be my daily driver for awhile.
Old 11-30-2016, 01:46 AM   #6
andrewmp6
Maybe leave it at ride height for a while just in case your compressor freezes.Or figure out a way to add a fill port to the tank and use a co2 tank or another air you can get.
Old 11-30-2016, 01:52 AM   #7
j.rigby15r
j.rigby15r's Avatar
Yeah right now I won't be able to drive to low the roads are terrible here during the winter. Why co2?
Old 11-30-2016, 04:41 AM   #8
andrewmp6
a co2 tank is basicly a portable air tank thats fill.Some people use them off road to run air tools and air up their tires after wheeling.
Old 11-30-2016, 08:22 AM   #9
PGSigns
PGSigns's Avatar
You could run a test on your compressors with a tank and a compressor and a battery. Set it all up in the garage then take it outside and let it sit a few hours and try to run it. Also ad a schrader valve that is easy to get to so you can just ad air with a compressor in the morning if needed before you go outside.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-30-2016, 11:23 AM   #10
ranger danger
ranger danger's Avatar
I've been driving trucks for years. I have always just put denatured alcohol in the lines. It displaces any moisture in the system.
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 12-03-2016, 09:54 PM   #11
t300
I drove mine a couple winters ago here in Manitoba, average probably -15-20 celsius with -25c not being uncommon. I dumped a ton of airline antifreeze in and that helped but the lines still periodically froze up. I drove it maybe 20 times that winter, the compressor which was under the cab on a framerail starting making an awful racket and wouldn't build pressure much past 50psi. And that was the last winter I drove it...
t300 is offline   Reply With Quote
Old 12-07-2016, 05:33 PM   #12
j.rigby15r
j.rigby15r's Avatar
Thanks for the input. Mine sits behind the rear diff which means it's completely exposed. We've been experiencing-20-30s over the past few weeks. I've thought about wrapping them in insulation to keep them warm.
