11-29-2016, 12:30 PM | #1 |
Neutral Start Switch
I'm needing to adjust my Neutral Start Switch and...
I can't seem to find any info on the location of this switch on my '72 GMC CUSTOM 1500. The closest I've found says at bottom of column. The bottom of my steering column is covered by the inner fender well. 350 engine w/TH350 automatic transmission |
11-29-2016, 12:35 PM | #2 | |
The Older Generation
Re: Neutral Start Switch
Look inside the cab at the bottom of the column. There are two small screws that attach it to the column 1/4 or 5/16. Don't take them out just loosen them up and the switch will rotate around the column a small amount. It doesn't take much to adjust it. LockDoc
11-29-2016, 01:42 PM | #3 |
Msgt USAF Ret
Here is a pic.
Look for two purple wires and two green wires.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-29-2016, 04:06 PM | #4 |
thanks...I was told to look underneath the hood...wow
11-29-2016, 04:07 PM | #5 | |
