Old 11-29-2016, 08:58 PM   #1
sixty4bigwindow
sixty4bigwindow's Avatar
Faulty flex line in CPP disc brake kit
Ok, so after a few months of my rig being out at my father in laws house, doing the full front drop spindle, disc brake conversion, the only thing holding me back from being roadworthy is the passenger side flex line leaking. We couldn't bleed the front brakes because there was no vacuum from air getting in. Put the compressor to the front steel line off the prop valve. And heard the air coming out of the banjo fitting on the line.. measuring it with the micrometer, it is about .010 difference, making it slanted and not a good bite, even in the copper washers, you can see it's not fully seated.. summit says they're back ordered and i cant get a replacement until end of December..
My question is, can i just run a fatter copper washer? Or sonce the fitting is most likely jacked, do i have to wait for the replacement?? I just want to drive my baby since its been almost 8 months thanks for the help guys!
sixty4bigwindow is offline   Reply With Quote
Old 11-30-2016, 07:57 AM   #2
PGSigns
PGSigns's Avatar
Re: Faulty flex line in CPP disc brake kit
Sounds like a trip to the parts store is in order. If you us a factory style line for a 73 and up truck you have to tweek the bend at the banjo bolt just a bit. I have done this on both my trucks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-30-2016, 10:37 AM   #3
scoot_mcgrute
I ran into a similar issue with my brake hoses from CPP but the reason mine leaked was because the line was on the caliper backwards. It wasn't off by much but it was enough to cause all kinds of problems bleeding the brakes. Flipped it around with new copper washers and it was all better.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 11-30-2016, 12:46 PM   #4
sixty4bigwindow
Jimmy, so thats the one with a longer angled brass fitting, correct??
Scoot, which side did you put on the caliper? It looks as though it should only fit one way..
Old 11-30-2016, 02:18 PM   #5
scoot_mcgrute
I felt kinda dumb for doing it the other way but the flat side goes to the caliper. The little tab on my hoses didn't stick out very far beyond the copper washer so I didn't catch it until bleeding time when I had a small leak.
1966 Army Truck
Old 11-30-2016, 02:37 PM   #6
sixty4bigwindow
Hmm ok scoot, i think that might be my issue. Ill check that and retry! Thanks man
Old 12-01-2016, 08:43 PM   #7
sixty4bigwindow
Quick question, did the kits you guys got come with 2 sets of washers? Mine has a thin and a thicker set. I started with the thin set, should i try the thicker one?
Old 12-01-2016, 11:40 PM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
Check your hoses as well, there may be a "stepped" side under the banjo fitting.
Old 12-03-2016, 05:36 PM   #9
sixty4bigwindow
Scoot that worked! Thanks man!! but if you look at my new post, cant bleed the system with the prop valve.. any suggestions??
Old 12-03-2016, 06:08 PM   #10
luvbowties
luvbowties's Avatar
Smile Re: Faulty flex line in CPP disc brake kit
Gravity bleed the system? HTH; and enjoy the challenging fun!
Sam
luvbowties is offline   Reply With Quote
Old 12-05-2016, 10:52 AM   #11
scoot_mcgrute
Awesome, glad that fixed the leak!
I'm not sure on why the proportioning valve won't let you bleed the system. Are you using the brake pedal to bleed the system?
My buddy has a Harbor Freight bleeder that didn't work well for me so we ended up doing it the old fashioned way.
1966 Army Truck
