Got a Start
Today I got a start on my 84 K10. Pulled rear drums to redo brakes and pulled the front axle assy apart for new calipers, axle joints, ball joints, and wheel bearings. Cleaning up parts so it can go back together. Next I'm going to check out the 305 and decide whether to replace it. I have new headers, HEI dist, 600 Holley and a performer intake. Along with plugs, wires, hoses, and water pump. Somewhere along the way, I got to recover the seat, carpet, and redye the door panels and repair the dash paint and dye. I need a arm rest for the drivers side, and I got a kit coming to redo the head liner. Never done 1 before so this ought to be interesting. What do you do on the seat foam? I got a cover from LMC, any pointers on this would be appreciated.
Re: Got a Start
That's cool!
How about copying your post and starting a build thread in the Projects and Builds section? Post some pics of what you're starting with and then the progressive steps. It'd be cool (er) if you did. Glad that you got started on it. Hope you enjoy it. LT7A Last edited by LT7A; 11-30-2016 at 06:01 AM. |
Re: Got a Start
Going to try and do a build thread. Thanks for the comments.
#4 | |
![]() Join Date: Oct 2014
Re: Got a Start
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=5 The headliner: It's pretty easy, just be patient and take your time. I did mine and it turned out great. If your using the original headliner board, just be careful with it, it's going to be brittle on the edges. I would suggest watching a how to video on YouTube. That what I do for almost everything I have tackled myself on the truck. I will attach a pic of mine. And also a before & after, of headliner I did in a Civic. I gotten my fabric from both places: http://www.yourautotrim.com/auheclvifa.html. You can even order a fabric card, to pick out your color. From this place, I like the headliner adhesive, that comes in their kit: https://www.miamicorp.com/default.as...temcode=MS2100 Bench Seat: Hopefully your foam is still in good condition and you won't have to do anything with it. If it's not, a replacement foam can be purchased through LMC & USA Industries, but man they are expensive. About $200 and that's just for the bottom section. And check out all your springs, if you have any that are broke, you can get replacements from USA also. I would go with them, LMC wants about $250 for their foam. I would just suggest getting a good set of hog ring pliers. The ones they give you with the seat cover, they will will test your patience!! https://www.usa1industries.com/1981-...ower-only.html Or you could have me restore and recover a seat for you and you wouldn't have to mess with it at all. Check out the thread to see everything that gets done to the seat or use it as a reference, if you do it yourself. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=715398
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 11-30-2016 at 01:50 PM. |
Re: Got a Start
I wish I could have somebody do it, I just can't afford it. Went in the garge today and the left side gas tank was leaking. Going to need all the brake stuff on the rear, plus axle seals. May as well do axle bearings. Done have new calipers and pads, new wheel bearings, LS was bad, and new ball joints, RS was bad. RS axle joint was bad. It's like a chain reaction.
Re: Got a Start
I need a LS arm rest and a LS map pocket, or whatever you call it. I'll try and post them in the WTB. Right now I need alot of things.
