Help Installing axle shaft.... will NOT seat
An axle seal failed so I'm replacing all seals, bearings and ruined brake shoes.
I removed the bolt and pulled out the steel rod to remove the C-clip. Then removed the C-clip from the diff to pull the axle shaft and begin bearing and seal replacement. After after replacing bearings and seals I lubricated the seals and bearings both. I tried to install the axle shaft but it will NOT fit. It binds up and will not travel the last 3 inches. What am I doing wrong? I tested bearings and seals for fit on one of the axles shaft because they make 2 different sizes. So I tested for proper fit before installing them. Is there a special trick get them aligned? I welcome any suggestions. BTW, it's 1981 K10 4x4 Thanks
1980 C10 short bed step side, 350 4 bolt main, 700R4. 1982 K10 4x4 long bed fleet side with Cummins 4BT |
Re: Help Installing axle shaft.... will NOT seat
It's the old wiggle and turn. Just have to keep at it. Remember you will have to push down on the axle to lift the splines up. Good luck!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
Yep, what he said. You have to get the end up to spline through the spider gears.
Thanks everyone for your help but it fits now.
So yesterday the axles sat in the hot sun and could not get them to fit but early this morning it fit perfectly. Only difference is that it hit freezing last night and early this AM I shoved them in nicely... ![]()
