62' stepside on 64' chassis
Ok I have a 62' going on a 64' chassis and I know I have to move some mounts. My bed is a fleetside.and I have the opportunity to get a 62' shortbed stepside. Can it be made to fit on the 64 chassis will it bolt on?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 62' stepside on 64' chassis
You can make anything fit and a short fleet and a short step use the same mounts. Be sure to check your local DMV about the VIN/ chassis difference before you sink a lot of money/time in it
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes it will work with a few mods. However as Clyde65 said, check with your local DMV before getting to carried away with the swap. You will need to find out what they require to make a frame swap legal since your cab and frame VIN's will no longer match.
