12-01-2016, 03:31 AM | #1 |
1956 steering column bearing question
My truck has a stock column and steering wheel. The top is has back and forth play in it, can I replace the upper bearing and where would I buy this? How hard is it to replace?
Thanks for your help Mark |
12-01-2016, 12:02 PM | #2 |
Re: 1956 steering column bearing question
classic industries part number. comes with the horn contact and wiring pigtail. check the website for more info with a pic.
Product #: T70855 In Stock Now! MSRP: $54.99 ea Classic: $49.99 ea try this site to see a couple of pics of what it looks like. http://www.hotrod.com/articles/power...traight-axles/ not that easy to see but better than nothing. it details the install of a power steering unit so scroll through the pics and you will come across a couple of pics of the top end column area. there is a bearing, the kicker woule de finding a new one. |
12-01-2016, 12:31 PM | #3 |
Thanks, just what I'm looking for
12-02-2016, 10:44 PM | #4 |
FYI - I replaced that steering head bearing in my 49 ( same as TF series). I had changed to R&P steering. Anyway, I had the same play and I could hear it, too - drove me nuts. When I changed the bearing, it was just as bad. However, I have a mustang ll FE and R&P steering, & I think the needle bearing design just doesn't work with that. If you have the stock steering, (leaf spring FE) with the heavy steering box as an anchor on the frame, a new bearing is an easy fix with good results.
I had to change, so I used a plain ididit straight hot rod column & someone adapt a 54 steering wheel to it...much, much nicer + also gained self-cancelling turn signals.
Pics of Finished 49 AD: https://www.flickr.com/photos/103194...7686536275403/ Pics of build process: https://www.flickr.com/photos/103194...57684031425944 Last edited by Hampshire; 12-02-2016 at 10:51 PM. |
