Do our trucks have a cab vent?
My doors are a real PITA to close unless one of the windows is partially rolled down. Is there a vent to allow air out of the cab?
I had the same issue with my last truck. Any help would be great. Thanks, Gasasaur. |
Post Whore
![]() ![]() Join Date: May 2015
Re: Do our trucks have a cab vent?
Mines the same way...I redid my cab and never saw a vent anywhere..
There are small vents in the door. But still have problems. I just shut the doors hard
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Do your doors have the striker bushing on them? If not they can be real hard to close. If you don't have any, use some electrical tape around them.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
ive been slamming 73-79 squarebody doors since i was 4. its a way of life
- When the Reaper makes his deal, trust in your steel - '77 C10 350/350 2/4 drop and a mild street engine |
yup.. should be a plastic bushing. if not, go to the hardward store and get a piece (or scrap) of PEX pipe. I had to cut a slit in mine to get it over the stricker bolt (take bolt off and slide on the pipe). works like a champ.
Agreed - I thought this was BS since I was slamming the doors on my truck for years, and couldn't see how that would really resolve the problem. Tried this as a last ditch, and haven't had to slam a door once!
![]() Join Date: Jun 2015
Just wondering if adding cab vents and repairing the strikers would a "double" benefit. I know a lot of newer trucks have them between the cab and bed. Anyone tried this?
Just wondering out loud.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
#10 | |
If the door closes easily at that point - you know you have a venting/pressure problem. If the door is still hard to close then you know it is in the hinge/latch/seal subsystem. These doors are fairly lightweight and short and therefore have never closed with just a push. Compare them to a passenger car door (like from a two door) in terms of length and mass and I think you will see what I mean. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#11 | |
K
Post Whore
I think he stated in the first post it closed easier with the window cracked...mines the same way..cracking a window makes it much easier to close..I've got all new strikers and hinge bushings and door gaskets..the rubber valve thingy was disintegrated on mine and I didn't bother repairing it..
#13 |
Yes, mine is definitely a venting problem. Both sides close nicely with window partially down.
#14 |
Keith, where is that door vent in your picture? I see the "fins" on the bottom of the door in the metal, is the rubber behind that?
#15 |
My 83 C20 doors are not easy to close like a modern truck, but replacing the hinge pins and door striker/bushings helped a lot. I can give the doors a good push or pull and they will close easily. It doesn't take very much slop or misalignment for the door to hang up and close hard. I don't think pressure is a problem with my truck. I would only use genuine GM door pins and bushings.
#16 |
I did the PEX bushing. It was about $2 for 8 feet of 3/4 PEX, and I still have 7 feet left after fixing several friend's trucks as well. Seems my driver's side one is not working as well after 2 years but another little bit should fix that.
#17 | |
It has a plastic carrier with thin rubber floppy pieces. K
#18 |
like this:
