Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 12-01-2016, 01:32 PM   #1
1962 Panel
1962 Panel's Avatar
Major rust repair
Hi everyone, recently I have been researching and contemplating what would be the best way to repair the rust on my '62 4x4 panel truck. The rot is pretty extensive in the firewall/ floor/ kick panel areas and the cab mounts have long since disappeared leaving the body to be supported by the bellhousing The easiest way to remedy this would probably be to get a clean body but being that it is a panel truck and not easy to find, that would likely be the most expensive option as well. I was perusing craigslist the other day and came across a pretty clean 64ish cab that had a tree fall on it and crush the roof. Upon seeing this I got the idea to cut out the ENTIRE floor portion, lower firewall, and kick panel area all the way to the top of the fresh air vent and attempt to graft it to the panel truck body. Any thoughts? Anyone done it before? I'm no expert when it comes to welding and fabrication which is why I am apprehensive to just patch up what I have because there are a lot of places that they don't even make patch panels for Any input would be much appreciated!
1962 4x4 Panel Delivery. 327 / 300 HP, Orig. SM420, Rockwell T221, 10 Bolt Rear/ Dana 44 Front. Project.
1977 Ford LTD, 302/C4, 18,000 mile survivor, daily driver.
That's right, a Ford. I'm bi-partisan.
1962 Panel is offline   Reply With Quote
Old 12-01-2016, 09:18 PM   #2
65sub
65sub's Avatar
Re: Major rust repair
jonzcustomshop did something similar. Check this thread http://67-72chevytrucks.com/vboard/s...tomshop&page=3
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 12-02-2016, 04:20 PM   #3
1962 Panel
1962 Panel's Avatar
Thanks that's very helpful
