Old 12-01-2016, 02:57 PM   #1
badd71
Active Member
1960 c10 front drum backing plate interchange
Does anyone know what years will fit a 1960. I pulled the wheel off and passenger side had no brakes. Backing plate bent and wheel cylinder wired to top of a-arm.
badd71 is offline   Reply With Quote
Old 12-01-2016, 03:13 PM   #2
PGSigns
PGSigns's Avatar
Re: 1960 c10 front drum backing plate interchange
Looks like a good time to update the entire brake system. I have some 66 stuff just dont know if they will fit. I would go ahead and put the duel pot master cylinder on it and split the brakes. Looks like it needs all new lines and this would be the time to make it safer.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-05-2016, 09:07 PM   #3
vietnmvetr65
Sir: If you can't find out if any other backing plates will work for you, I have a pair of front backing plates off of a 1960 Chevrolet Apache 10. Let me know and we will see what we can work out. Ron
vietnmvetr65 is offline   Reply With Quote
Old 12-06-2016, 11:44 AM   #4
badd71
Active Member
Thank you for the responses. I was able to use a 1969 c10 backing plate. Brakes are fixed for now.
