Old 12-01-2016, 05:47 PM   #1
scotty72
72 chevy c/10 heater fan issues
Can anyone help determine why my heater fan isn't working on my 72 c/10 w/ ac ? My control switch makes the relay click when I go to lo, but fan doesn't work in any speed. Thanks
scotty72 is offline   Reply With Quote
Old 12-01-2016, 05:56 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 chevy c/10 heater fan issues
Try unplugging the heater motor under the hood and run a jumper wire from the battery to the +12v connector on the motor and see if it runs.
LockDoc
Leon
Old 12-01-2016, 10:27 PM   #3
pound41
Not going to be any help but mine does that on every speed except medium. I have replaced everything blower motor relay switches. Ran a ground wire to the battery. No luck
pound41 is offline   Reply With Quote
Old 12-02-2016, 01:51 AM   #4
LockDoc
LockDoc's Avatar
Did you replace the heater resistor?
LockDoc
Leon
Old 12-02-2016, 01:39 PM   #5
cdowns
cdowns's Avatar
you could always REMOVE THE FAN AND CHECK IT ON A BENCH WITH A BATTERY CAHARGER AND WHILE IT'S OFF CLEAN OUT THE CAVITY OF 45YEARS OF BUILT UP CRAP TO ALLOW AIR TO FLOW WHEN YOU GET IT TO WORK
