Old 10-11-2003, 09:12 PM   #1
redone71
redone71's Avatar
Question Is rocker backing needed?
If a person uses the front and rear-outer floor replacement patch panel, does the rocker backing need to be used? Or does the lower portion of these two afore mentioned pieces take the place of the backing? Also what size and grade bolts are used on the lower a pillar? Thanks for the help in advance.
On the eighth day, he made trucks and saw they were good.
redone71 is offline   Reply With Quote
Old 10-11-2003, 09:47 PM   #2
Tim Christian
Tim Christian's Avatar
Smile
No, You don't need the backing plates in you are using the floor repair panels.
Tim Christian is offline   Reply With Quote
Old 10-11-2003, 09:49 PM   #3
redone71
redone71's Avatar
Thank you Tim!
Old 10-12-2003, 08:30 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I didn't use them with my 2 trucks. It's just another place for mud and junk to collect and cause rot. I just left the back area open to breath. They are plenty strong too.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
