Old 10-11-2003, 09:31 PM   #1
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Dual Tank question
Hey i was wondering how difficult/expensive it is to hook up a second tank on a truck that only has 1. Let me know if there is like a kit you can buy or somehting like that. Thanks, NICK
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 10-11-2003, 10:32 PM   #2
TX_Mudder
JCW sells the switching valve you need. It comes with a switch you can mount in your cab, but I think it looks cheesy. The factory switch, from a jyard, would work well.
Then, you will need the tank. I recommend poly. Then you need a sending unit and the straps. All this assumes your bed already has a gas tank door on the other side. If not, I hope you don't mind siwtching beds or mig welding a fuel door in.
It's doable, but will not be cheap. WHy not get a burb 40 gallon tank and put it behind the axle where the spare tire used to go?
TX_Mudder is offline   Reply With Quote
Old 10-11-2003, 11:16 PM   #3
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Thats a good idea, have you ever mounted a burb tank or know someone who has? If so, was it complicated? The only reason is because i have a built 350 pushing 430 horse, and it goes through 16 gals real quickly. BTW its a Shortbed
Old 10-12-2003, 08:26 PM   #4
TX_Mudder
Yes, I have seen two trucks in person with this done. Have seen it online quite a bit too.
Big tank, and helps put some weight on the back (our trucks are so forward heavy.)
I wish I had done this instead of getting a 2nd poly side saddle tank. Oh well....
Old 10-12-2003, 08:28 PM   #5
TX_Mudder
Oh, as far as being complicated - no it's no. You need to fabricate the holding straps. It would help to have a welder, but you can do it all bolt on. I have seen it done both ways.
