Old 12-02-2016, 06:54 PM   #1
mzsigler
Suburban Third Row in a SWB
I know i've read about this before but I've sifted through a ton of searches and can't seem to find anything about it.
I picked up a donor vehicle for my 82 SWB, it's a 2005 Yukon XL, the interior matches the Almond interior in my 82, and I would like to use the seats out of it in my 82. I seem to recall hearing about using the third row seat, but everything I can find is about using the third row in the back of Blazers. Is this still what I want to use for a regular cab pickup?
Yeah, I know the easy way is to measure stuff, but my wife is going to be induced in the next couple of days and for some reason she doesn't want me to run off to play with car parts
Here's the third row:
Here's this universal mount setup for it I found on Ebay:
http://www.ebay.com/itm/00-2014-Univ...ZSvF5z&vxp=mtr
Is this going to work or am i nuts?
96 Miata FM 2.5 suspension, roll bar, brakes, hardtop.
82 C10 Turbo LSx build in progress:
http://67-72chevytrucks.com/vboard/s....php?p=7764896
mzsigler is offline   Reply With Quote
Old 12-02-2016, 10:08 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Suburban Third Row in a SWB
The third row will be too narrow for a single cab. They're designed to fit between the rear wheel wells, so likely around 48" wide, and your stock bench seat is likely around 64" wide or more.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 12-02-2016, 10:20 PM   #3
MusicMan70
MusicMan70's Avatar
Congratulations mzsigler on the upcoming blessing!
A lot of people use the later front Tahoe seats or even Cadillac seats, both with the integrated seatbelts.
That third row seat will be too short across. The seat bottoms may not be long enough for your bottom or lacking in thigh support.
Here is a link to how the single seats would look in a 60-66. Notice that those are mounted high in a fixed position.
http://www.persh.org/Pickup/Third-Row.htm
I found a link where a guy used some square tubing, removed the clamping hardware, and bolted them to the factory seat stands.
http://www.67-72chevytrucks.com/vboa...hird+row+seats
I went ahead used that idea for my 61 suburban. They slide fore and aft and I will add my own console later on.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-02-2016, 10:23 PM   #4
mzsigler
That's the impression that I got, thanks. Will any of the seats from a Yukon XL work?
Old 12-02-2016, 10:25 PM   #5
mzsigler
Thanks! And thanks for the links, I'll do some reading.
