12-02-2016, 11:03 PM | #1 |
Timing chain info needed please.
396 BB engine, #1 at TDC. Do the dots on the gears go 12 and 6 o'clock or 12 and 12? Thanks in advanced.
12-02-2016, 11:32 PM | #2 |
Re: Timing chain info needed please.
If you're talking #1 tdc compression then it's 12 and 12.
And if you think about it, 12 and 6 is impossible. |
12-02-2016, 11:39 PM | #3 |
So then crank at 12 and cam at 6 would be #6 compression?
12-02-2016, 11:43 PM | #4 |
20' Daredevil (Ret)
If 12 and 6 is impossible, I'm missing something. Wouldn't that be the crank gear mark at 12 oclock, and the cam gear mark at 6 oclock, something like in this pic? One more revolution and they'd both be at 12 oclock.
12-02-2016, 11:44 PM | #5 |
Yes crank gear at 12 cam gear at 6. Put chain on and rotate both to 12 before dropping distributor in.
12-02-2016, 11:46 PM | #6 |
Yup!!
12-02-2016, 11:47 PM | #7 |
Yes they would both be at 12. I just want to make sure i'm dropping distributor in at right plug location, not 180 off.
12-02-2016, 11:50 PM | #8 |
Thanks all. Love this site.
12-02-2016, 11:51 PM | #9 |
20' Daredevil (Ret)
My manual doesn't cover BBC, only SBC, but I believe they are the same. It shows 12 and 12 with #1 at TDC, and 12 and 6 with #6 at TDC. We're all on the same page then.
12-02-2016, 11:53 PM | #10 | |
If you rotate the crank from the dot at 12 down to 6 then the cam gear only turns a 1/4 of a rotation, not a half rotation.. i |
12-03-2016, 12:00 AM | #11 |
20' Daredevil (Ret)
No, I misunderstood and thought you meant you couldn't have the crank at 12 and the cam at 6. It's all good though, we're all in agreement.
12-03-2016, 02:35 PM | #12 |
12 and 6 is when the dots are aligned, so that should have been brief!
