'70 front hub/drum issues
I am putting new shoes on the front of my C10 but the passenger side drum won't come off of the hub. I pulled the axle nut and took the hub and drum off but I cannot get the two separated. It looks like there are rivets that run through the drum into the hub but that doesn't make sense, any thoughts?
1986 C10 LWB 350 1970 C10 LWB 350 - Sold |
Re: '70 front hub/drum issues
Drill or grind out the rivet...That's the way it left the factory
Look here: http://67-72chevytrucks.com/vboard/s...d.php?t=384059 |
You can also remove the dust cap and take out the hub/drum as an assembly, do the brakes, and put it back together. No grinding needed unless you are turning or replacing the drum.
Thanks, so I just pulled the axle nut and the whole assembly. I put in the new shoes and spring kits on both sides, I still have no pedal so I have to get to bleeding tomorrow I suppose.
![]() Join Date: Jul 2016
Your problem with no pedal is probably shoe adjustment. Adjust the shoes through the slot until very tight, then back off until slight drag is felt. You will never get a pedal without the shoes adjusted first.
Thanks, I will give that a shot before I bleed the system! Just for the record, I am not a fan of changing brakes on drum systems...
Rottenwood Garage Member
As cheap as the brake parts are, go ahead and replace the wheel cylinders and hoses at the same time if you have never done it.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
I just recently replaced all the brake lines and the master cylinder. I am hoping to finally get a good firm pedal so I can drive this thing a little bit.
