Old 12-03-2016, 03:14 PM   #1
2B32
Figuring Out Frankenstein
I've been slowly working on getting my 72 K20 4x4 back on the road. Both axles were replaced at some point with 1/2 ton axles, but I have no idea what they came from, or if they even came from the same donor.
At this point I'm tired of trying to backtrack and figure things out. I haven't had any luck finding model correct axles near me, and this was never meant to be a show queen so I'm not worried about it being "perfect." Are there other 3/4 ton axles, and leaf springs, I can easily swap in so I know what I'm working with? This is my first project, and I'm trying to do as much myself as possible, so the simpler the better.
2B32 is offline   Reply With Quote
Old 12-03-2016, 04:44 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Figuring Out Frankenstein
Any front axle from 71-87(91) will bolt in and have disks. One ton 73-91 4x4 rear will bolt in but you'll have to move the shock mounts around on the axle. Other than that your stuck to 67-72 4x4 rear end being bolt in. The 73-87 rears other than one ton will work but you got to move perches and shock mounts on the axle. All 71-87 (91) Front springs will bolt in rears will not. Someone feel free to add or correct me if I missed something.
Your truck had a 3/4 ton Dana 44 and likely an Eaton ho52 rear end from the factory.
Tyler
57taskforce is offline   Reply With Quote
