Old 12-03-2016, 09:42 PM   #1
hotrodder
just got a 65 GMC
I just bought a 65 GMC swb and I am wondering how you figure out what model this truck is! It is a basic truck, 6cyl, three on the tree, stepside, no power, just a truck. So is it a 1000, 1500, or what? Chevrolets are much easier to identify.!!!!!
hotrodder is offline   Reply With Quote
Old 12-03-2016, 10:03 PM   #2
pimpston65
pimpston65's Avatar
Re: just got a 65 GMC
pics are always welcome...
pimpston65 is offline   Reply With Quote
Old 12-04-2016, 01:17 AM   #3
Captainfab
60-66 Nut
Is the engine the V6 or an I6?
Old 12-04-2016, 08:44 AM   #4
slorio
slorio's Avatar
Hotrodder:
Have you looked under the dash at the plate on the left kick panel? Also, what is your VIN on the plate inside the door frame at the top of the drivers' door? The info you are looking for will be in those two places.
regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 12-04-2016, 12:00 PM   #5
60-66
60-66's Avatar
Being a short wheel base its a 1000 .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-04-2016, 12:01 PM   #6
60-66
60-66's Avatar
http://6066gmcguy.com/VinNumber.html
Old 12-04-2016, 12:07 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
I6? V6?
If you can provide a vin I will decode it for you.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-04-2016, 01:24 PM   #8
hotrodder
Thanks for all the help. The truck is a 6cyl. vin# on the title is :
11001PF41886A. I can't get the left door open right now there is another truck right next to it to see what the tag says. The truck is a one owner sold new about 25 miles from here. It is a project for sure, but will run . Get some pics out later
Old 12-04-2016, 01:27 PM   #9
jtrichard
The question was is it a V6 or a straight 6?
jtrichard is offline   Reply With Quote
Old 12-04-2016, 02:54 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
I understand it is a 6 Cylinder, What I am wondering is if it's an INLINE 6 or a V6.
Here's the vin decode:
10: Half Ton
01: 115 inch wheelbase (Shortbed)
P: Manufactured in Pontiac, Michigan
F: 65 or 66 model year. No differentiation between them in the vin.
3188: was the 3188th unit to roll off the manufacturing plant.
A: 6000 pound GVW
To be sure it's a 65, the only engine option would be the 305E or I believe a 230 I6.
66 has the option of the 351 v6.
Old 12-04-2016, 03:53 PM   #11
factorystock
factorystock's Avatar
11001PF41886A.
The answer is in the Vin# 11001. 1 = I series straight 6 1001 1/2 ton short wheelbase.
factorystock is offline   Reply With Quote
Old 12-04-2016, 10:05 PM   #12
hotrodder
yep it is a straight 6, always had Chevrolets, so the V6 thing wasn't a factor there, anyway thank you to all for the info.
