12-03-2016, 10:02 PM | #1 |
How would you repair this frame?
Is it repairable? I have a SWB,coil spring suspension frame with some severe rot where the coil springs mount. The vertical section of frame rail is pretty thin and cracked on left side. Right side is just thin. I was thinking of adding a plate on outside to fix that. The horizontal bottom sections of frame rail have a curve to them. I was thinking of cutting out the bad and welding in a new piece,but how do I match the curvature? Will heating to bend the replacement piece with oxygen/acetylene torch weaken the metal? OR.. Should I find that section or complete rear 1/2 and weld it in? No-Limit has a kit that replaces the ENTIRE rear portion of rails,but it is $1,100 and requires bed floor to be raised 4",which I don't want to do. Does Porterbuilt kits replace any of what I have that is rotted?
David Last edited by Rocket3; 12-03-2016 at 10:04 PM. Reason: add words |
12-03-2016, 10:25 PM | #2 |
Re: How would you repair this frame?
Rot on one side ,thin on the other ? That frame is done , it's cheaper to buy another short bed frame .
12-03-2016, 10:29 PM | #3 |
You can't weld rust, and I'm not sure you have enough virgin metal there to weld to. If I did try to repair it, I would grind it down to good metal, weld plates inside the frame rail, and box in that section of frame for added strength. As far as bending a repair patch, a little heat and a big whupping hammer would be my tools of choice.
"Negative people always seem to have a problem for every solution" |
12-03-2016, 11:52 PM | #4 |
All about them K’s
I've sold cuts from that portion of frames in the past for patches it can be done. If your going to patch it, I'd personally go with patches from a good frame and not try and plate what you've got.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-04-2016, 06:25 AM | #5 |
I would be searching for another frame, that there is really weak metal now.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
12-04-2016, 07:04 AM | #6 |
Times two. Safety is number one.
12-04-2016, 07:29 AM | #7 |
I have a short bed frame and long bed frame listed for sale in the classified section , I'll cut the long bed frame for parts but it's much easier to just replace your short bed frame .
12-04-2016, 07:44 AM | #8 |
Rottenwood Garage Member
With your geographic location, you are close enough to many areas outside the rust belt. Recycle your frame and use the cash for a tank of gas to drive south and get a different frame. You can pick up a roller for $400 or a bare frame for $200 all day long!! Contact board member UNCLE.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
12-04-2016, 07:50 AM | #9 |
You are only like 4 1/2 hours from Grumpy
12-04-2016, 09:51 AM | #10 |
I would replace unless you have some really good fab skills and a good frame for a patch
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-04-2016, 12:53 PM | #11 |
I know where there is a good frame, likely less expensive than to fix yours. I bought a custom frame, and Truck Haven in Unionville TN has my old frame, which has no damage and hadn't ever been hit that I could tell. It even has all new suspension under it, ball joints, tie rods, springs, shocks... Chuck is the guy who has it, I believe he sold the differential out of it, but it would certainly be less work (and likely less expensive). I'm about 3 1/2 hours south of Paducah, and he's another hour south of me. His number is 931-205-5926. I did some trading for sheetmetal with him. Nice guy. Wish I would have found this site before I started my build....
12-04-2016, 05:47 PM | #12 | |||
I have searched him on google maps to find distance. He is on my list. Quote:
David Last edited by Rocket3; 12-04-2016 at 05:49 PM. Reason: add |
12-04-2016, 06:50 PM | #13 |
The frame was a 1970 frame, 5 lug wheels of course with disc brakes (normal I believe for a 1970?)... It is a short wheel base, with coil springs on the rear. The trailing arms were, I believe, brand new as I couldn't find a mark on them anywhere, and the bushings were all good. Brake lines were on the frame when I traded it to him, and it was a power steering truck. All steering parts were also on the frame when we traded. As I stated, the springs and shocks were new, I can't really remember about the discs, but am thinking they looked good. I bought the truck out of Alabama, and am putting it on a chassis from Scott's. When the cab came off for metalwork, I traded the frame for doors, and the front sheetmetal for a '68 because I like the nose better.
Good luck, you might find a better one local. I got more in trade for mine than I've seen prices floating around on this site... |
