Dash cluster connector
Hello,
I purchased an American auto wire Power Plus 13 harness. I am rewiring my son's 69 Chevy C10. I'm am using the stock dash cluster. Also I purchased a new dash cluster connector from Brothers. I am connecting the wires to the new cluster connector. I am having some trouble where some of the wires go on the new cluster connector. I attached some pictures of some of the wires I have attached to the connector already. Not sure what other wires from the American auto wire harness I need to hook up to the new cluster connector. Also where can I buy some terminals that go into the cluster connector. I ruined a few of them while I was crimping them. Thanks, Ramiro |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Dash cluster connector
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
I just happened to have my dash cluster of of my truck and it has the aaw harness. The first picture you posted looks the same as mine but my slot 7 has a black ground wire. Slot 6 is the green temp sender,slot is not used,slot 4 is tan gas gauge,slot 3 is pink 12 volt ignition,slot 2 is tan brake light wire from proportioning valve. I have attached photos of the instruction sheet. Hope this helps
Thank you Beadblaster. Hope I can finish making my new dash cluster connector with you pictures. I do have the black wire on the 7 on the connector. Do you where I can purchase more of those terminals for the connector?
Classic industries has the connectors
BW900216 - 1967-81 Pinted Circuit Board Connector Problems with your circuit board connector? Here is the solution. This connector includes terminals for both gauge and non-gauge vehicles. Look under electrical wire and connectors |
Old member
This is the connections depending on which style you have. Lights are gauges.
![]() ![]() Here is the one for gauges. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
