10-11-2003, 11:29 PM | #1 |
dash board weight?
How much does the stock dash..gauges and heater..dash pad..the whole shebang weigh????
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
10-12-2003, 09:41 AM | #2 |
Why ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-12-2003, 09:56 AM | #3 |
Im pulling mine out to put a cage in. and if its heavy enuf..IE 75+lbs I will leave it out and do a sheet metal(aluminum dash)
10-12-2003, 11:33 AM | #4 |
Fabricate till you "puke"
if you are pulling dash heater & all, my guess is that you could shave 75-100 lbs. I never did weigh the heater stuff that I pulled from the longhorn, & would be interested to know exact weight if you do check it.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-12-2003, 08:44 PM | #5 |
67-72 Addict!
Wow Jim, next come the wheel tubs!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-12-2003, 11:05 PM | #6 |
i would think maybe 75 pounds including the wiper motor heater controls and all i know the cab itself is damn heavy at 560 pounds with just front glass stripped and no doors but i would think with as thin as the sheet metal is in the dash that it really isnt gonna make that big of a difference
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
