Junior Member
Spot weld cutter
Just got a neat tool from Napa. It`s a spot weld cutter that really helps in removing those pesky spot welds when replacing panels. You have to watch it so you dont drill through the back piece of metal, but it has really saved me some time. The part # is 770-3841 if anyone is interested. Just thought I`d pass this along.
Scott
71 C10 Step Daily Driver 72 K10 Suburban Work in Progress www.louisianaclassictruckclub.com |
Thanks, every time I drill all the way through and then have to weld up all the holes. I keep telling myself that I'm going to get one, but haven't yet.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
1969 Custom 30 wrecker
I bought some from a cheapy tool store in my area. These things work great! Everyone should have a few.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
What is this wonderful tool of which you speak!
71 GMC 1500 LWB |
Basically a fancy drill bit. Are they really worth getting? I keep thinking I should get one.
#6 | |
Resident Young Old Dude !
It is a "specialty" drill bit, that has a relatively small bit at the tip of a bigger bit. The bigger bit is Flat, not angled.
It is designed for the small portion to go through both pieces of the spot weld, but the large part only goes through one piece of the two ( of the metal) Then when you re-use the part you needed, it gives you one solid piece to weld to. I got mine from Piston. Ron Quote:
I bought a set from Snap-On a while back. Blue-Point "Rotabroach Sheet Metal Cutters" Part# GA219B. Best thing since indoor plumbing.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
Junior Member
The NAPA tool sells for about $12 and is well worth the money in the amount of time it saves you.
hee hee, I paid $5.99 each! (but im a cheapskate)
These are Taiwan jobs but cut through those welds like butta'. ![]()
Yeh It's Fast
![]() ![]() ![]() ![]() Click here to view pictures of my truck ![]() ![]() ![]() ![]() Zwijndrecht, The Netherlands Europe |
I bought a cutter off the shelf at the local parts store. It looks just like the one in the napa link. The "cutter" is obviously reversable. My question is how do you reverse it?
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
ive tried the ones like the napa one, it sucked. eastwood has some pro ones that look real good. http://www.eastwoodcompany.com/itemd...1.x=52&I1.y=63
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
#13 |
My Taiwan cutters are just like in the Napa link above. To reverse, you unscrew the black cutter part and turn it around. (notice cutting teeth on both ends)
#14 | |
![]() jk....couldn't resist that one! |
#15 |
Junior Member
Saw the ones at Eastwood, looks like they would work well. I was just in a hurry and NAPA got the tool the next day. It has worked fine for me though. I just center punch the weld and start slowly and it rips right through the weld.
#16 |
The drillbit from napa is called a blair cutter made by blair ind. they work good but be careful not to angle the bit while drilling, it will break and "walk" across the panel your'e working on. If you are drilling a lot of spot welds get the wivco"spot eze" brand bits like what eastwood sells they last alot longer and you can drill in closer areas. Of course you could just buy a spot weld drill and avoid all the effort-work excellent-a little testy though, mine was $500.
you never have too many suburbans.... Last edited by sbrban; 10-17-2003 at 12:48 AM. |
#17 |
here's the drill-it went down in price even!http://206.117.149.144/acb2/showdetl..._ID=30&CATID=3
you never have too many suburbans.... |
