Old 12-04-2016, 09:58 PM   #1
Rustyo61
wheel help
I have a 61 that I have installed a front crossmember from a 85. Got 6 lug rotors and cpp drop spindles. Looking at the cragar delux 69 wheels. Should I go with 15 by 7 or 8 and what kind of back spacing? Rear end is staying stock for know what's a good fit for the rear. Tire size suggestions also would be great. Thanks for the great forum. Could have not gotten as far as I halve without everyone's help
Rustyo61 is offline   Reply With Quote
Old 12-08-2016, 09:30 PM   #2
Rustyo61
Re: wheel help
Any help out there
Old 12-08-2016, 10:20 PM   #3
MusicMan70
MusicMan70's Avatar
Re: wheel help
Check out this link and POST #6 on Markeb01 GMC. Looks very tough to me.
http://www.67-72chevytrucks.com/vboa...hlight=cragars
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-09-2016, 12:34 PM   #4
Lugnutz65
Lugnutz65's Avatar
Re: wheel help
The tire width will help decide what wheel width to choose.
The 235/75R15 tire can go on a 7" or 8" wide rim and is a common choice and looks good. A wider tire like a 255/70R15 probably needs a 8" wide rim.
Do a little reading about what the numbers mean when you see tire sizes listed.
As far as wheel back spacing, I think 3.5" to 4" is about right. Any more than that and you will likely need wheel spacers, which adds to the hassle and cost. Make sure you do a test fit with the wheels you choose before you install tires. Make sure the front caliper clears the rim. Also, make sure the rear wheels have a big enough bore hole for the rear hub. It'd be a real shame to spend all that cash and find out that they don't fit.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 12-09-2016, 01:33 PM   #5
verdell
verdell's Avatar
Re: wheel help
This is my '60 with American Racing smoothies, 6-lug, 15 x 8's. Front tires were 255 60 15 and rears were 275 60 15. These wheels were purchased between 1989-1990 but if I remember correctly, the BS was 4". The truck has 2.5" drop spindles and 6-lug discs on these pics. Hope this helps.
verdell is offline   Reply With Quote
Old 12-09-2016, 10:05 PM   #6
Rustyo61
Re: wheel help
Thanks for the help.
