![]() Join Date: Jan 2015
4.8/4L60e purchase
Just picked up a 4.8/60e. I was able to drive truck before pulling. Transmission seemed to shift fine. Motor smoked a little when getting up to speed. This setup has 350k on them!
I am thinking that heads need rebuilt and bottom end needs to be re-ringed at least. New oil pump, gasket set, timing chain, and ARP bolt kit.... Anything else you guys would do? Thanks!
Jimmy Hoelzel |
meowMEOWmeowMEOW
Re: 4.8/4L60e purchase
Hard to know until you get the block apart. If you can just ball hone it a bit you can get away with a re ring. If the cylinders have any scoring on wall, its best to get it into a machine shop and see if a hone will sort it out, or if a small over bore is needed.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#3 | ||
"I ain't nobody, dork."
If you're that far into it... why not have the rods and crank checked and install new bearings. Peace of mind...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#4 | ||
Where is everyone ordering rebuild parts for LS motors from...Summit, GM???? Will defiantly be putting new bearings in it ![]()
Jimmy Hoelzel |
When i had trouble with my 2001 5.3 from the junkyard, i needed to bore the block because of rust pits. I happen to check on ebay and someone was selling gm's extra stock and i bought a new gm 4.8/5.3 block with cam bearings already installed for $199.00 plus shipping in 2014. In my hands was $324.00, stock perfect bores ready to go. I believe jegs or summit picked these up and this summer they had them for $3??.?? and free shipping, what a deal.
#6 | |
Jimmy Hoelzel |
