Old 12-05-2016, 11:38 AM   #1
J. Gatz
Solid 5 speed truck trans behind a 454
Hey guys, i have a 79 k10 that im doing a frame off restoration on. It came with a 350 and an abused 4speed. Iv pulled those an Im going to fix her up right and id like to put a big block in with a solid 5 speed behind it. I have no intentions of being hard on this truck. No wheeling, no racing, no pulling. Just a stout rig that's dependable. Any suggestions on a quality 5speed truck trans?
Thanks!!
J. Gatz is offline   Reply With Quote
Old 12-05-2016, 12:03 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Solid 5 speed truck trans behind a 454
Thanks!!
GM NV4500, Richmond, or Tremec 5 speed overdrive.
LockDoc
Leon
Old 12-05-2016, 12:31 PM   #3
jocko
jocko's Avatar
Agreed. T5 comes up in this discussion often, but it's more for a small-block hot rod or a 6, I wouldn't put it behind a big block.
Old 12-05-2016, 02:23 PM   #4
74CustomK20
74CustomK20's Avatar
Nv4500 with the fixes
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-05-2016, 05:46 PM   #5
Tom
driving is in my blood
Tom's Avatar
Most people won't put it behind a small block either, certainly not a hot rodded small block.
NV4500 is what the OP wants. OEM 5sp with a big block.
Old 12-05-2016, 09:38 PM   #6
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Clark VO, he said he wanted a truck trans.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 12-05-2016, 11:43 PM   #7
andrewmp6
Being he has a 4x4 the nv4500 is his only option really unless he wants to run a divorced t case.
andrewmp6 is offline   Reply With Quote
Old 12-06-2016, 12:01 AM   #8
mongocanfly
Post Whore
mongocanfly's Avatar
Ditto ditto ditto....nv4500
Old 12-06-2016, 07:14 AM   #9
hatzie
Moderator
hatzie's Avatar
Yup. For five speeds in a K series with a big block the NV4500 is pretty much it.
A Ranger OD gear splitter or Gear Vendors overdrive unit on the SM465 are other options. You actually get 8 forward gears with this setup but there's likely overlap.
The price of all three of the above end up being pretty much the same.
The NV3500 is a five speed, and can be had in 4x4 dress, but the torque capacity peaks at 290-300ft-lb... not enough for a Big Block 400 say nothing of a 454.
The S10 4x4 T5, rated at only 250ft-lb, doesn't have anywhere near the torque capacity for a mildly built smallblock, stock 6.2L Diesel, or even a 250 I6.
The NP440/A833 MM7 doesn't quite have the torque capacity for a 454 and, even tho it's an overdrive trans, it's a 4 speed.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-06-2016, 07:59 AM   #10
andrewmp6
Only thing i can think of is what t case will work on that nv4500.The newer trucks have a driver side drop and he needs a passenger side drop.
Old 12-06-2016, 08:53 AM   #11
dragn91
dragn91's Avatar
They make adapters to run all sorts of t cases behind the nv4500 but a round pattern 205 works with a cheap spacer. I got lucky and found my 205 and trans mount out of a 1988 squarebody one ton truck for $80 look for people parting out late model squarebodys with th 400 transmissions. Advanced adapters sells everything you need. I think a round pattern 208 or 241? Out of squarebodys would work as well but not as strong and you have to match the spline count on whitchever one you use to the trans. I think its 32 im sure someone will correct me if im wrong. Im putting this swap together now in my k30 behind a 6.2
dragn91 is offline   Reply With Quote
Old 12-06-2016, 09:13 AM   #12
hatzie
Moderator
hatzie's Avatar
32 spline GM LH drop NP241 and GM LH Drop NP208C are bolt up and go. These both have deep 2.72:1 low range and are fairly light weight. The NP208C is usually pretty cheap. I wouldn't hesitate to use either one. Despite comments to the contrary the NP241 & NP208 will put up with a fair amount of abuse before they let go. I beat heck out an NP208 plowing. It was mounted behind a 460 & C6 in a 1986 F250. The C6 transmission, the Dana 44 TTB front axle, and Dana 70 rear axles blew up along with one front propshaft but that transfer case held up for 6 years of harsh abuse. I did keep it full of the proper fluid and changed it out in the spring and fall.
NP205 will fit with adapters and modifications. The NP205 is fairly expensive, only has a shallow 1.96:1 Low range, is heavier than a dead horse, and some adapters require that you cut down the NV4500 mainshaft.
Whatever you do... Install a torque brace from the transfer case to the bellhousing unless you like snapping off transfer case adapters or transmission tails.
The later 1980's SM465 & all the TH400/3L80, and 4L80 transmissions have 32 spline output shafts. The TH350, TH700R4, & 4L60 are 27 spline outputs. The 80's GM CUCV M1008, M1009, etc are good donors.
Old 12-06-2016, 10:08 AM   #13
andrewmp6
Unless he wants a hardcore off roader a np205 is kinda overkill and pricey.Since the np208 will fit they are cheap easy to find and like said not as weak as people say.
Old 12-06-2016, 12:08 PM   #14
hatzie
Moderator
hatzie's Avatar
The main problem with the NP208/241 is the shifter is mounted to the floor not the transmission/transfer case. If the body mounts are loose the shifter can move some in relation to the driveline. That movement over time fouls the nylon wear buttons on the shifting fork just like resting your hand on the shifter knob.
There are several cable shifter kits. Novak and JB Custom Fabrication come to mind.
Novak makes a transmission/transfer case side mounted shifter for the 231, 241, & 242 that should work fine on the NP208.
You may be able to repurpose a console shifter by cutting out a custom gate plate.
Old 12-06-2016, 12:52 PM   #15
J. Gatz
Thanks so much for tour help guys! Happy to be a new member of this community!
Old 12-07-2016, 12:27 AM   #16
tucsonjwt
I have a SM465 and gear vendor in my 83 C20 454. You really can't get 8 gears with a gear vendor. The first granny low 1 gear is never used. You cannot engage the gear vendor until about 30 mph or the engine will lug. So, I engage the gear vendor between 3rd and 4th gear, so I only really have a 5 speed. I have a 4:10 rear, so with a granny 4 spd you don't get up to speed until 3rd gear.
tucsonjwt is offline   Reply With Quote
Old 12-07-2016, 02:53 AM   #17
andrewmp6
Welcome to the forum,We have a lot of people that know a ton about these trucks.We even have one member that use to assembly line when these trucks was new.When you get the chance start a build threat on here with your truck we always love to see more of them.And if you need anymore help with anything don't be scared to ask.
