12-05-2016, 02:09 PM | #1 |
Which trans crossmember to use?
Posting this for a friend. 1963 Chevy 1/2 ton shortbed. Wants to run a T56 6 speed manual trans with a 350 vortec engine. Will the stock transmission crossmember work or will he need to fab one? There is no crossmember in the truck right now.
12-05-2016, 05:06 PM | #2 |
Moderator
Re: Which trans crossmember to use?
I found this in a search:
http://67-72chevytrucks.com/vboard/s...12&postcount=3
12-06-2016, 01:44 AM | #3 |
60-66 Nut
An auto trans crossmember from a '63-'86 C series or '87-'91 R series truck, Suburban or 2wd K5 Blazer will work. He'll just have to drill the bolt holes once he gets it located in the frame. Then I would convert the e-brake cables to the '66-'72 style. That is unless he gets really lucky and finds a '63-'65 auto trans crossmember.
12-06-2016, 03:11 PM | #4 | |
12-06-2016, 07:23 PM | #5 |
12-07-2016, 12:52 AM | #6 |
60-66 Nut
Yes he should be able to. That is unless there is an interference with the T56 that is different than an auto trans.
12-07-2016, 02:31 PM | #7 |
Great thanks guys, I'll pass along the info
