serpentine belt
might sound a little silly to you guys, but, I need to find a Serpentine belt for my 2001 ls motor out of a Suburban.... I need one that will eliminate the power steering pump, do any of you guys have an idea of what I can use? The reason I am asking, I built a test stand, and don't want to run the pump, mainly because I don't want to hook up a gear box...
Thanks |
Re: serpentine belt
Just use a fabric measuring tape or a string (and measure it) to figure out what length belt you need. Then look up a part number for that length belt in a 6 rib. Should be pretty easy.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
meowMEOWmeowMEOW
Re: serpentine belt
Go to the Gates website and look at the belt sizing charts. They give you the part # for any length belt. I usually take the stock size, and then depending on the changes, buy a few part #'s either direction from my local Napa, and return what I don't use.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: serpentine belt
Gut the power steering pump insides and reinstall it with a little fluid in it and use the stock belt?? Pump cant make pressure or move fluid around without vanes, etc. Plug the outlet and return ports??
Re: serpentine belt
Thanks for the info guys!!!!
Re: serpentine belt
Hello Derek. To delete the power steering I bought a bracket which rerouted the belt so that the power steering pulley was no longer used. Duty dingo sells this part. I'll posted a pic when I get a chance.
Re: serpentine belt
Here you go.
Re: serpentine belt
Can you post MORE photos of your test stands please? i have been wanting to build one for a while and could use some motivation.
thanks -=Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
Re: serpentine belt
FYI the belt that I used is 69 1/8" long....
Re: serpentine belt
Cool! We need a video of it in action!
![]() Mike
Re: serpentine belt
I would like to load a video, but I cant seem to find how to do it... its a .MOV file....
Re: serpentine belt
https://youtu.be/Qf1KKo9ZrVg
well, I added it to YouTube, lets see if this works.... |
