Active Member
![]() Join Date: Sep 2013
2wd conversion front crossmember question
Just picked up this gem for free over the weekend. Actually pretty rust free. I will be converting to 2wd since I already have the front cross member, steering etc from a donor vehicle. YES I've done the whole search button thing and couldn't get my answer. Guys that convert to 2wd, where are you measuring from to get the crossmember lined up correctly? I understand it has to come forward. I heard that one measurement is 20 1/4 inches from core support rivet to crossmember nut. Thanks, Jon
![]() Posted via Mobile Device |
Re: 2wd conversion front crossmember question
I used the chassis gauge holes and compared to a original 2wd. An example of the gauge holes here http://www.chuckschevytruckpages.com/framespecs.html
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=511830 |
#3 | |
Active Member
1972 GMC C2500 Tow Rig project 1972 C10 Air Bag project 1967 C10 Drag Truck project 1967 GMC Patina Special project 1968 C10 I have no clue what to do with project 1969 GMC C6500 I wish I had more money project 1986 K10 I have too many damn projects |
the bolt holes 4 the bolt-in IFS r pre-drilled in the frame - use the donor parts from a 2WD and line up the holes
Active Member
Cool, thank you
