Old 12-06-2016, 10:44 PM   #1
KenAdams
KenAdams's Avatar
T56 & Slave Cylinder Fitment Help Needed
Bought a new GM Performace Parts T56 and install kit. The slave cylinder disconnect does not clear the transmission out of the box, is GM just this sloppy? One side of me says to pull out the die grinder, the other side of me says maybe I am doing something wrong?
KenAdams is offline   Reply With Quote
Old 12-07-2016, 01:44 AM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: T56 & Slave Cylinder Fitment Help Needed
Wow Mine pushed right it no problem
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-08-2016, 05:57 PM   #3
Shon
use a grinder
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-08-2016, 10:26 PM   #4
KenAdams
KenAdams's Avatar
Originally Posted by Shon View Post
use a grinder
Yep, spent 5 minutes with a flat file, cleaned it up and it fit just fine. Doesn't line up with the bell housing but it works:
The upper hole for the bleeder looks like it was milled correct. Guess someone went to lunch and forgot to finish when they got back that day.
Old 12-09-2016, 08:17 PM   #5
Tork?
Ah the ole Friday build
Tork? is offline   Reply With Quote
