Old 12-07-2016, 06:37 PM   #1
bbbc10
Diggin The SquareLife
12 bolt rear end
are the 67-72 12 bolt rear ends an 73-87 12 bolt rear ends the same diff cover bolt pattern? reason I ask is I have a 12 bolt rear end that was under my 81-87 swb frame an a guy is selling a watts link that is for 67-72 12 bolt rear end an I need to knw if it will bolt up to my 12 bolt rear end
bbbc10 is offline   Reply With Quote
Old 12-07-2016, 08:42 PM   #2
69heavychevy
69heavychevy's Avatar
Re: 12 bolt rear end
covers are the same, btw 80 was the last year for 12 bolts. mounting points/dimensions are different, also have to figure trailing arm/leaf spring differences
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 12-07-2016, 09:38 PM   #3
bbbc10
Im not worried bout all that....i jus need to knw if the bolt pattern for the diff cover is the same
Old 12-07-2016, 10:34 PM   #4
friscobob
My 81 seems to have a 12 bolt.
friscobob is offline   Reply With Quote
Old 12-10-2016, 12:52 PM   #5
Bloodhound
Same here. I thought 81 was the last year.
Bloodhound is offline   Reply With Quote
Old 12-11-2016, 03:56 PM   #6
friscobob
Did the 12 bolt end in 81 or? What was it replaced with? Is the replacement a bolt in for earlier chassis? Which is better, 12 bolt or later?
Bob
Old 12-11-2016, 05:56 PM   #7
Matt Man
Matt Man's Avatar
12 bolts were available until 81 (my truck has one with a detroit locker) Starting in 1982, the trucks came with the corporate 10 bolt rear end pretty similar in strength but the 12 bolt has bigger axle shafts, but a smaller pinion gear. However, the pinion gear usually doesn't break on 12 bolts, but the 10 bolt rear ends break axle shafts easier.
I think parts are cheaper for the 10 bolt, you can build both to be pretty strong. But in a stock comparison, the 12 bolt is stronger.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-12-2016, 01:18 AM   #8
69heavychevy
I stand corrected...
