Cluster lights dim, turn and high beam indicators on
Help
On my 70 gmc, I have an intermittent issue. The cluster lights go dim (all except the one on the far right of the gas gauge). When this happens, both torn sugnsl indicators are lit dim as well as the high beam indicator. If I turn the high beams on, the cluster lights all but turn off they go so dim. I would wiggle the headlight harness and just stuff in general and they would all be fine again. I feel it's a ground issue or the printed circuit board but what grounds are for the cluster? Any help or insight is appreciated! Posted via Mobile Device |
![]() Join Date: May 2013
Re: Cluster lights dim, turn and high beam indicators on
Try running a jumper wire from the printed board to the metal dash for ground
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
I was thinking that was my first plan of attack. I appreciate the confirmation.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
SOLVED - I added a ground wire from the back of the cluster board bolt to the chassis. No more issues.
When you say "back of the rhe cluster board bolt", what do you mean. I have the same exact issue with mine. I went and bought a new printed circuit, thinking that was the problem.
#6 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
There are small sheet metal screws around the perimeter of the cluster that will work as grounding points. You can use any one of those that is convenient. There are also some in the circuit board that hold it to the metal tin which are grounded to the metal as well. see this picture. and this one shows how to wire in a voltmeter in place of the battery gauge. The purple wire is the ground side of the voltmeter and it is connected to one of the screws that could be used. There is also a ground wire that goes to the cluster plug to pin 7 if I recall correctly, which if it had a poor connection, would result in the symptoms described by the original poster, where he could jiggle the wiring harness and get the lights to work.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
In the picture in VetteVet's post, it was the screw above the speedo and to the right of the upper illumination bulb. It was loose already. I plan on putting a spade terminal there so in case I have to remove the cluster, I can just pop it off.
Well I answered my own question when I took my dash out. It wasn't a ground issue, though I do thank those for the responses, because now I understand.
When I was fiddling with adjusting the tach, I screwed up my printed circuit to the point it was FUBAR. Right now I have my dash sitting on my coffee table with a brand new printed circuit. As an added measure, I'm going to put the additional ground on, because we all know how these trucks love grounds. ![]() |
