12-08-2016, 11:22 AM | #1 |
Carpet question
Doing my homework and getting ready to buy carpet for my 71 Blazer. I like stockinteriors.com, anyone every deal with them??Why would they ask if it's a CST ??
12-08-2016, 11:30 AM | #2 |
Re: Carpet question
A CST carpet is narrower about 3" in front and behind the wheel well tub because of the side panels. The previous owner of my truck made this mistake and bought CST carpets for it, even though my truck is non-CST. I've used ACC carpets on previous restorations and really liked their quality and fit.
12-08-2016, 11:42 AM | #3 |
Re: Carpet question
So,not knowing if mine is or ever was a true CST,it would be better to order non-CST carpet??
12-08-2016, 12:22 PM | #4 |
Re: Carpet question
If you are going to install the side interior panels, buy for cst. If not, buy the other.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
12-09-2016, 12:17 PM | #5 |
Re: Carpet question
Thanks guy's
01-16-2017, 11:21 PM | #6 | |
Re: Carpet question
01-16-2017, 11:56 PM | #7 |
Re: Carpet question
No grommet hole on the ACC carpets I have bought. I just tap the carpet with my foot and it works
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
01-17-2017, 12:28 AM | #8 |
Re: Carpet question
01-17-2017, 01:25 AM | #9 |
Re: Carpet question
The kit should come with a plastic grommet that covers the hole that you must cut out for the dimmer. I have always used ACC.
01-17-2017, 01:55 AM | #10 |
Re: Carpet question
Excellent - thanks! Do you go with the 80-20 loop or Nylon? Which one is closest to original? Also, do you order the mass backing? I am going to put in some type of dynamat as well. Final question - do you have any comparison of carpet over wheel wells vs not? Just curious how much sound difference it makes. Mine currently has the carpet over the wheels but I like the original look without.
01-17-2017, 03:30 PM | #11 |
Re: Carpet question
I put carpet over the wheelwells because I put Dynamat on them. The mass (jute) backing will make the carpet feel better, but it's a moisture trap. Our Blazers are known for leaks so I wouldn't use it.
If you order a carpet from ACC, it will come with a dimmer grommet like the one in the picture. |
01-17-2017, 08:05 PM | #12 |
Re: Carpet question
I used cut pile for a newer look on my Blazer. I have used the loop also and it looks just like original carpet. If I were to do it again I would use some sort of spray on sound deaden-er instead of stick on mat because of the moisture concerns like posted above. But I will say that dynamat + carpet padding + full carpet made a HUGE difference. I drove around with bare metal floor and 2 chamber flowmasters for a while and it was pretty loud.
01-18-2017, 12:08 AM | #13 |
Re: Carpet question
I used stock interiors carpet with mass backing. It's really nice. The only thing I wasn't prepared for, having never put in new carpeting, was there were no holes for the seats or dimmer or makings to even get me close. I spent almost three days in my garage in the Texas heat last summer putting it in. Lots of crawling underneath and back into the inside. Wore me out but it's done. Picked up some floor mats for the front, passanger and rear area and I'm pretty happy with it.Hers some before and after pics....
72 Chevy 2WD Blazer |
01-18-2017, 10:09 PM | #14 |
Re: Carpet question
Awesome thanks guys. If anyone has any feedback on how much of a difference covering the wheel wells with carpet/dynamat makes that would be great. I'd prefer to go with the original look of leaving them off but want my interior to be nice and quiet.
01-19-2017, 04:20 PM | #15 |
Re: Carpet question
A Blazer that's quiet?
01-20-2017, 10:48 AM | #16 |
Re: Carpet question
I have Dynamat covering the wheel wheels in my Blazer. Makes a slight difference for everyday driving. Big difference when driving in the rain or dirt.
03-01-2017, 01:08 AM | #17 | |
Re: Carpet question
03-01-2017, 03:20 AM | #18 |
Re: Carpet question
Sounds like you ordered the cst carpet kit. It is not as wide in the rear in front and back of the wheelwell because the cst side panels would've covered that part. The non-cst goes all the way to the inside body.
03-01-2017, 08:50 AM | #19 | |
Posted via Mobile Device |
03-01-2017, 10:08 AM | #20 | |
Re: Carpet question
It they cut the carpet right to the corners, then there would be no room for the wheel well carpet. As far as the back being too short, are you sure you don't have it in wrong ( front to back)? Last edited by hemi43; 03-01-2017 at 10:18 AM. |
03-01-2017, 10:53 AM | #21 | |
03-01-2017, 03:38 PM | #22 | |
Re: Carpet question
03-01-2017, 03:57 PM | #23 | |
03-07-2017, 11:09 PM | #24 |
Re: Carpet question
I have the same problem with my carpet. It's as if the wheel well cutouts are not centered correctly. There is roughly 15 1/2" carpet behind the wheel well and without pulling the carpet up the front of the wheel well it won't be under the rear carpet strip. I'm not happy at all, I bought the carpet a year ago and am just getting to it. I went with the mass backing as well and am wondering if I'm out of money on the back half of the kit. It's at least 2" too short. The front fit no problem.
Kirk 72 Blazer CST 4wd highlander |
03-07-2017, 11:51 PM | #25 |
Re: Carpet question
Glad I saw this post.... I was on the fence about getting the essex carpet set from ACC or doing the interior with spray in liner.... I think I'll go with the liner and skip the fitment issues.
